2008 Xsara Picasso 1.6 HDi, cranks but won't start
BumbleBee24
New User
Unread post by BumbleBee24 »
Hi guys, we've got a 2008 Picasso with a 1.6 HDi engine that will turn over fine but just won't start, it won't even "run" on easy start or brake cleaner (don't worry, it's a demonstration car, we'd never use brake cleaner on a daily driver [-X) we've cracked off the unions at the injectors and we're getting fuel there when cranked. It sounded like it was gonna go a few times when trying it with the brake cleaner, but it still didn't.
There's no error codes when plugged in, we've bypassed the glow plugs and checked the timing. It ran when it was parked up maybe 12 months ago and we've tried a few times since to get it going with no joy. Compression is OK as well.
Anyone have any ideas? Fuses to check etc? I'm guessing it's either electrical or an air issue since our other demonstration car with the same engine starts with brake cleaner and that doesn't even have a fuel rail on it!
Thanks in advance :-D
x 1481
Re: 2008 Xsara Picasso 1.6 HDi, cranks but won't start
Welcome along
You need to get it on a diag computer - it needs to see engine rpm, crank / cam synch and fuel pressure before it will start. That it won't run on brake cleaner is suspicious. Are you sure the timing belt is intact... they like to shed teeth.
PaulC5
x 665
Unread post by PaulC5 »
Is the key being recognised by the immobiliser ? Put it in the ignition switch and then open the driver's door - if recognised you ought to get a warning.
xsara92
x 3
Unread post by xsara92 »
Had this with my old 2008 Xsara Pic once and what happened was, the chip in the key had fallen out of its place inside the key body, had to be put back then all was well
