Guys,
How do I disable the RHS one touch window control on a Xantia?
The LHS window works perfectly (so the relay's OK?), The RH window doesn't work at all.
Power is getting to the one touch control box in the door via the two green wires from the switch, but no power is getting to the red & yellow wires to the window motor.
I'd gladly put up without the one touch thing if I can only get the window working, it's getting hot in there!
