xantia heater control panel
crooser
i have just repaired the plastic gear wheels in the heater panel on a 97 xantia.easy to get to, all the screws are accessible. but then you have to pull the unit out about 3 inches to release the cables and thats where the problem starts.all the spare room under the dash and citroen in their wisdom make the cables the minimum length.if the cables had been a couple of inches longer the whole job would have been easy.it got me to thinking how many other jobs on a citroen would have been easy if some design team had thought of aftermsrket access.how much easier a cambelt change would be if there was another inch,or radiator removal and no doubt a dozen other jobs.no wonder people turn down secondhand citroens for the simple reason that "you can't work on them"
Stuart McB
crooser
nick
