elec windows
mark bodsworth
elec windows
Unread post by mark bodsworth »
Is it possible to use a one touch switch from the drivers side on any of the other windows?
Stuart McB
Unread post by Stuart McB »
You'll need to fit the appropriate relay for the window you wish to do. As I have found out the automatic bit is not the switch itself but is a separate relay and new switch.
crooser
Unread post by crooser »
hi stuart,do you know if you just replace the existing relay or add an extra one and wiring?i have one touch on the drivers side,does that relay do all windows or just the one?if the relay does all windows i presume i just need to change the switch.[95 xm 2.5]
PowerLee
Unread post by PowerLee »
You will need the little black window control box & the one touch switch & the plugs that go with them ( You might want a pair of switches )
Also the plug that plugs in the window motor.
Ive done this mod to my 405s front passenger window, I unplugged the Peugeot cables & switches & added the one touch set up.
All the factory cables are still there & tucked away.
Just make sure you use the correct cable for the job & a fused supply!
You can get away smaller cable for the one touch control box & switches, The heavy cable is just needed for the window motor & the control box power supply & earth.
