Hello all.
Not sure where I should ask for this but I'd like the build sheet for my diesel c3 aircross. ( Vin VF7**************[VIN obfuscated, can be read by forum staff])
Was also wondering if there is a definitive date, or at least a more narrowed down date, for when the improved 8mm chain engine began being installed?
Thank you
Dave
Build sheet request
- x 1056
Re: Build sheet request
Here you go
C3 AIRCROSS (A88) FAMILY SALOON 1.5 BlueHDi 111 (DV5RCE Euro 6.4) STT TYPE 6-SPEED MANUAL GEARBOX
Vehicle characteristics
Vehicle family C3 AIRCROSS (A88)
AS/RP N° 17241 VB 1 0242
Warranty Start Date 20/03/2024
Engine serial number 10 Q4DF 0150002
BER e4*2007/46*1241*21
P4A 9851039499
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C3 AIRCROSS (A88)
SILHOUETTE FAMILY SALOON
TRIM LEVEL MEDIUM HIGH
ENGINE DV5RCE UE64 1.5 L DIESEL
TRANSMISSION STT TYPE 6-SPEED MANUAL GEARBOX
PAINT TYPE PAINTED METALLIC EXT TRIM TYPE
BODY COLOUR PEPERONCINO RED PAINTWORK
INTERIOR TRIM TYPE HALF LEATHER B71 "4Y"
UPHOLSTERY COLOUR "FT"
GEARBOX (CHARACTERISTICS) MB6GW
DEFINITION TO FOLLOW MID-LIFE
ENGINE (TYPE) DV TYPE ENGINE
ROOF (EXT. ASPECT) BODY COLOUR ROOF
OTHER BADGE WITHOUT FULLER BADGE
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE FAMILY BADGE
SPEEDOMETER DRIVE WITHOUT SPEEDOMETER RATIO
Fuel supply-Engine
FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 6.4 ENGINE EMISSION CONTROL
CAPACITY 1500 CM3
REAR IMPACTS STANDARD RR BUMPER
FUEL TANK NON-PRESSURISED FUEL TANK WITH LOCATING TAB
FUEL TANK INSULATION WITHOUT FUEL TANK INSULATION
COOLING MOTOR RADIATOR TH : 18 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
VALVE PER CYLINDER 2
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
DEVICE (ANTIPOLLUTION) EXHAUST GAS RECYCING "EGR" + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTION EURO 6.4 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
FAN 1 AERO 2-SPEED 140W FAN WITH SCOOP
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
DRIVE TRAIN INTERNAL COMBUSTION DRIVE TRAIN
TANK FILTER CITHOUT RESERVOIR FILTER
STOP AND START WITH STOP AND START STARTER
Gearbox Transmission
FINAL DRIVE RATIO AXLE RATIO 19 X 75
WHEEL STYLE STYLE 16 INCH STEEL WHEEL
CLUTCH HYDRAULIC CLUTCH
DIFFERENTIAL (GEARBOX) 84 DIAMETER DIFFERENTIAL
RIM/TYRE SIZE 16 INCH TYRE FITMENT
TYRE (SIZE, TYPE) 205/60 R16 92H NON REINFORCED TYRE
WHEEL (TYPE) MOUNTING OPTIMIZED STEEL WHEEL
INFLATION PRESSURE LOSS INDICATOR INDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION
GEARBOX TYPE MB6 TYPE GEARBOX
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR WITHOUT REAR ANTI-ROLL BAR
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 22
BRAKES (CIRCUIT) WITHOUT BRAKE PROTECTION
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLE WITH ABSOLUTE STEERING WHEEL ANGLE ESTIMATOR
SUSPENSION NORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT BOSCH 9.3 ESP
Body fittings
TOWBAR WITHOUT TOWBAR
AERIAL AERIAL + GPS + GSM
OPENING ROOF (APPEARANCE) WITHOUT SUN ROOF
FINISHER (SELF-ADHESIVE) MATT BLACK REAR SURROUND TRIM
SIDE MOULDINGS (TYPE) WITHOUT LATERAL PROTECTORS
WHEEL EMBELLISHER (STYLE) 16 INCH BABYLON STYLE WHEEL TRIM
EXHAUST TAILPIPE SINGLE EXHAUST OUTLET
UNDERBODY SHIELD PLASTIC PROTECTION FOR UNDER BODY+TANK
REVERSING LAMPS WITH 1 REVERSING LIGHT
INDICATORS LUMINOUS SIGNATURE
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
WASHER JET STANDARD SCREEN WASH JET
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRIC FOLDING EXTERIOR MIRROR+DIODE
ENGINE BAY SOUNDPROOFING UNDERBONNET + BULKHEAD SOUNDPROOFING
WINDSCREEN GLASS (TYPE) STANDARD WINDSCREEN GLASS
WINDSCREEN WIPER 2-SPEED INTERMITTENT WIPER + ADJUSTMENT
REAR SCREEN WIPER (OPERATION) AUTO INTERMITTENT RR WIPER IN REVERSE GEAR
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER BUMPERS FR/RR DUAL-TONE
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP NO FRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC) COLOURED HEADLAMP MASK
PANORAMIC VISUAL AID WITHOUT PANORAMIC VISUAL AID
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) ELECTRIC DRIVER’S EXTERIOR MIRROR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASSENGER ELECTRIC DOOR MIRROR
SPARE WHEEL WITHOUT SPARE WHEEL
EXTERIOR ACCESSORIES BODY COLOUR EXTERIOR HANDLE
SPARE WHEEL MOUNTING STANDARD SPARE-WHEEL CARRIER
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CURVED EXTERIOR MIRROR GLASS
SUN ROOF WITHOUT SUN ROOF
BUMPER TRIM BUMPER TRIM PAINTED FAIRING
GLASS (APPEARANCE) TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE) LAMINATED WINDSCREEN + TOUGHENED REAR SCREEN
HANDS FREE ACCESS AND STARTING WITHOUT HANDS-FREE ACCESS/STARTING
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT FRONT HEADREST ADJUSTABLE
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
BLIND SPOT DETECTION WITHOUT BLIND SPOT MONITORING
LUGGAGE COVER SHELF
REAR SEATBELT PYRO LAT RR SEAT BELT RETRACTOR + 3 POINT BELT
FRONT SEATBELT RETRACTOR ALARM DRIVER + PASS S/BELT
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
AIR CONDITIONING AIRCON WITH MANUAL AIR INLET
CHILD LOCK MANUAL REAR CHILD LOCK
SPEED GRADUATIONS SPEED GRADUATION IN KM/H
GRAB HANDLES PASS FR HANDLE + REAR + HOOK
CONSOLE LONG OPEN CONSOLE
DRIVING POSITION LEFT-HAND DRIVE
REMOTE CONTROL WITH REMOTE CONTROL
MIRROR LINK WITH MIRROR LINK
LOAD SPACE LIGHTING WITH GLOVEBOX LIGHTING
BOOT AND LOAD SPACE LIGHTING LOAD VOLUME + BOOT LIGHTING AUTO CONTROL
DASHBOARD EQUIPMENT GLOSS GREY DECOR
INT. TRIM AND EQUIPMENT VARIATION STANDARD HANDBRAKE KNOB
MISC. INT. LAMPS WITH MAP READING LAMP
LOAD SPACE TRIM BOOT CARPET MAT
UNDERSEAT STORAGE WITHOUT UNDER SEAT STORAGE
INSTRUMENT PANEL (CHARACTERISTICS) LCD INSTRUMENT PANEL + TEXT
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS
RADIO CONTROLS STEERING WHEEL AUDIO SYSTEM CONTROL
POLLEN FILTER WITH POLLEN FILTER + ACTIVATED CARBON
PASSENGER COMPARTMENT SOUNDPROOFING W/O CAB SOUND-PROOFING
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL MANUAL DRIVER’S SEAT CONTROL
DRIVER SEAT ADJUSTMENT DRIVER’S FR SEAT CUSHION ADJUSTMENT ADJUSTABLE BACKREST
FRONT PASSENGER SEAT ADJUSTMENT ADJUSTMENT FRONT PASSENGER SEAT CUSHION RECLINING SEAT BACK
FRONT PASSENGER SEAT FOLDING WITH STANDARD FOLDING FR PASSENGER SEAT
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBS ECO LED
REAR WINDOW LIFT SEQENT CONTR RR WINDOW LIFTER
TRAFFIC INFORMATION READER WITH LATERAL TRAJECTORY MONITORING
CABIN CARPET FR+RR PASSENGER COMPARTMENT MATS
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
DISPLAY 9-INCH HD DIGITAL TOUCH SCREEN
CUSHION PADDING PADDING WITH PASSENGER DETECTION PAD
FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
PASSENGER AIRBAG WITH AIRBAG ON PASSENGER SIDE
ON-BOARD COMPUTER COMPUTER
EXTERIOR REAR VIEW MIRROR (HEATED) HEATED EXTERIOR MIRROR
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE) CHROME FINISH INSIDE DOOR HANDLE
COURTESY LAMP FR+RE DOORS CONT - FR+RE INTERIOR LAMP
FRONT SUN VISOR DRIVER + PASSENGER SUN VISOR WITHOUT INSCRIPTION
WIFI WITH WIFI
STORAGE (DRIVING POSITION) LOWER ODDMENTS TRAY WITH FLAP
RADIO RECEIVER DIGITAL CONNECTED NAVIGATION
REFRIGERATION SINGLE AIR CONDITIONING
CRUISE CONTROL REGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROL DRIVER’S SEAT HEIGHT MANUAL ADJ
INTERIOR REAR VIEW MIRROR DAY-NIGHT INTERIOR MIRROR
AIR CON./TEMPERATURE REGULATION WITHOUT REGULATION AIRCON/TEMP
STORAGE (OTHERS) W/O OTHER SETTING BOXES
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE W/O BOOT TIDY
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM REAR RADAR OBSTACLE SENSOR
LATERAL BLINDS WITHOUT SIDE BLINDS
TRIM ADAPTATION LEATHER KNOB + PVC GAITER
FLOOR MAT W/O CARPETMAT
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL LEATHER COATED STEERING WHEEL
CHILD OBSERVATION INTERIOR MIRROR WITHOUT INTERIOR CHILD MONITORING MIRROR
AUDIO PACK AUXILIARY SOCKET 1 USB SOCKET
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT 3S
Electrical
ALTERNATOR ALTERNATOR CLASS 18 180 AMP
BATTERY L3 760 70AH EFBC 760 BATTERY BECOMES EFBC
STARTER MOTOR STTD STARTER
SPECIAL LIGHTING DAYLIGHT RUNNING LIGHTS
MULTIPLEXING ECO ELECTRICAL ARCHITECTURE
BATTERY CHARGE MEASUREMENT WITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF LIGHTS
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION C-YOU
MODIF. DURING MODEL YEAR WITHOUT MINOR MODIFICATIONS
CONDENSER (SPECIFICATIONS) CONDENSER 19.2 DM - THICKNESS 12CM
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
AIR CONDITIONING PIPES STANDARD AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET SINGLE ACCESSORY SOCKET
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTS STANDARD SIDE BUMPERS
SET OF KEYS 1 HIGH FREQUENCY REMOTE CONTROL KEY+1 MAIN KEY ONLY
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT PUNCTURE REPAIR KIT
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
ADDITIONAL TYPE APPROVAL PLATE W/O ADDIT HOMOLOGATION PLATE
P4A 9851039499
General information
BADGE FAMILY BADGE
Fuel supply-Engine
CAPACITY 1500 CM3
ABS WITH ABS BRAKES
Body fittings
Interior fittings
LUGGAGE COVER SHELF
WIFI WITH WIFI
Electrical
Miscellaneous
Spanish Dave
Thank you very much. Greatly appreciated
