Hello All,
I have a 2015 Ds3, it has the standard factory boring radio fitted, I have managed to get a Sat Nav unit with dab from a 2015 ds3, i have alittle issue mine hasnt got the sos button and the wiring on mine is different, has anyone else over come this issue.
Cheers for your time
Sat Nav Unit
- x 6947
Re: Sat Nav Unit
You realise you can't just swap these out?
Depending on the replacement unit you have (SMEG or NAC), it will require the correct harness, fascia, programming and VIN coding that will require a dealer (unlikely they will do this though as it's not the original system / liability issues).
MickyR25
Re: Sat Nav Unit
Hi, yes I understand it's not a straight swap, I have all the parts but I think I need the dash harness, the unit I have is a Smeg, cheers
