C3 1.4 hdi 2006
darrin
- x 3
C3 1.4 hdi 2006
I was having injector knock on my c3 1.4 hdi and poor fuel efficiency. I Connected to the launch X431 Diagnostic OBD tool Which informed me there was to high pressure in the common rail around 1200 bar. So I replaced the fuel regulator valve but the car would not start? So I put the old one back in and the car started but still not running good. I had the injectors tested and 3 of them were not good so I ordered 4 Remanufactured injectors now the car will not start again? I have gone to two garages with no luck and they seem not interested in looking at the car. Can anyone give me any advice or information help please
PaulC5
- x 717
Re: C3 1.4 hdi 2006
Do you have the fault codes before doing anything and ones you are now getting ?
darrin
- x 3
Re: C3 1.4 hdi 2006
Before I change the injectors I had high pressure falt code witch I can't remember exactly. Now with the new injectors I have no codes. By the way do now want the voltage should be at the low pressure valve on the fuel pump so I can test it as I think the engine is not getting fuel ?
