Hello all
I have a 2008 Mini with the DV6TED4 engine fitted - pretty much identical to a 2008 PSA car .
This car uses an EOLYS bag in a plastic holder - there's a PSA pump as part of the unit and we have a broken connector on the end of the pipe from that pump to the fuel filler. (Connector has broken O rings in it)
I cannot find any part numbers for this connector and I see the Stellantis problem in the part numbers thread.
Has anybody got a source for a replacement connector?
Good used would be fine but I simply cannot find any !
Bit of digging - the original PSA fitting is a Norma RSS branded 5/16" in and about 4mm out. These are actually to an SAE standard - J2044 so can be purchased from many manufacturers. The problem is that finding a 90 degree elbow with a small barb on it is kind of tricky - Norma are available but really just from USA.
There are UK based folks that sell similar fittings both on eBay and elsewhere - I'm going to try https://www.ebay.co.uk/itm/187035124555
