Would like to update the display software for my Citroen C4 (2015)
milancen
x 6
Unread post by milancen »
Hi, i would like someone to tell me if its possible to update the display software on my Citroen C4(2015)
The information is following:
Software: SMEG5.3.A.R3
CD: 26302
Can someone point me to the right direction and tell me which version is the newest compatible with mine and point me to some links I can download it.
Thanks in advance
x 1938
Re: Would like to update the display software for my Citroen C4 (2015)
Unread post by Paul-R »
Yes there are several later versions (5.43.A.R2 is the latest and last) but can I ask why you want to update? If you're hoping to get some extra features then you'll be disappointed. The updates are issued to correct faults and if you're not having any problems then I would caution you to be careful.
milancen
x 6
Paul-R wrote: 26 Mar 2025, 19:52 Yes there are several later versions (5.43.A.R2 is the latest and last) but can I ask why you want to update? If you're hoping to get some extra features then you'll be disappointed. The updates are issued to correct faults and if you're not having any problems then I would caution you to be careful.
Hey thanks a lot, no particular reason for update, just taught newer the version better, but I will listen to your advice. Everything works as expected with this version and I won't be changing anything. Can you maybe point me where can i find newer maps for my nav system, currently have this version of maps: DbDw_281/Gr_406. Specifically it's Southern Eastern Europe.
Thanks a lot,
Milan
x 1938
Check your private messages.
