Hello,
Anyone able to check and send me my DS7 vehicle specs. Like trim level, equipment, etc
VIN:VR1**************[VIN obfuscated, can be read by forum staff]
Best Regards
DS7 Vehicles Characteristics
- x 1060
Re: DS7 Vehicles Characteristics
Here you go
Vehicle characteristics
Vehicle family DS 7 CROSSBACK (X74)
AS/RP N° 16068 88 1 0285
Warranty Start Date 26/11/2020
Engine serial number 10 DY3G 4028600
BER e2*2007/46*0601*13
P4A 9839102799
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE DS
VEHICLE FAMILY DS 7 CROSSBACK (X74)
SILHOUETTE S.U.V.
TRIM LEVEL UPPER MEDIUM
ENGINE DIESEL DW10FC FAP 132KW
TRANSMISSION STT TYPE 8-SPEED AUTOMATIC GEARBOX
PAINT TYPE METALLIC LACQUER
BODY COLOUR EVL - PLATINUM GREY PAINT
INTERIOR TRIM TYPE NAPPA LEATHER "4H"
UPHOLSTERY COLOUR "FI"
GEARBOX (CHARACTERISTICS) AMNG8
CONVERSION GUIDANCE WITHOUT CONVERSION
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) EW/DW
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE WITHOUT BADGE
Fuel supply-Engine
FAN ONE 2-SPEED FAN 140 W DYNAMIC AIR SHUTTER RB45
DRIVE TRAIN INTERNAL COMBUSTION DRIVE TRAIN
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START WITH STOP AND START ALTERNATOR STARTER
FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
FUEL FILLER CAP WITHOUT FUEL FILLER CAP
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 6.2 ENGINE EMISSION CONTROL
SPEED SENSOR SIGNAL FRONT WHEEL SENSOR NON-SIGN RR SIGNED
ENGINE (TYPE) EW/DW
CAPACITY 2000 CM3
CATALYTIC CONVERTER CATALYTIC CONVERTER BELOW 50PPM
FUEL TANK NON-PRESSURISED FUEL TANK WITH LOCATING TAB
FUEL TANK INSULATION WITHOUT FUEL TANK INSULATION
COOLING MOTOR RADIATOR EP28 28DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) POWER 130 KW - 400 NM EHZ
SPECIAL POWER TRAIN SOUND WITHOUT POWER TRAIN ACOUSTICS
EOBD SELF-DIAGNOSIS SYSTEM WITH "OBD" AUTO-DIAGNOSTICS
VEHICLE TECHNICAL DEPOLLUTION EURO 6.2 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
Gearbox Transmission
GEARBOX TYPE GEARBOX TYPE AMN8
FINAL DRIVE RATIO AXLE TORQUE 15 X 53
WHEEL STYLE STYLE5 20 INCH ALLOY WHEEL
CLUTCH WITHOUT CLUTCH
RIM/TYRE SIZE 20 INCH TYRE FIT
TYRE (SIZE, TYPE) TYRE 235/45 R20 100V NON-REINFORCED
DRIVING WHEELS 2 DRIVEN WHEELS
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR INDIRECT DETECTION OF UNDER-INFLATION WITH LOCATION
Suspension-Steering-Brakes
BRAKE ASSOCIATED VARIANT ESP BOSCH 9.1
STEERING (OPERATION) HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) PEDAL ALUMINIUM
REAR ANTI-ROLL BAR ANTI-ROLL BAR DIAM 19
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR STIFFNESS 32500 NM/RAD
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLE WITH STEERING ANGLE SENSOR
SUSPENSION NORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
Body fittings
HANDS FREE ACCESS AND STARTING WITH HANDS-FREE ACCESS/STARTING
TOWBAR RETRACTABLE TRAILER HITCH
HORNS HORNS-HARMONY
SIDE MOULDINGS (TYPE) CHROME SIDE PROTECTORS
SIDE MOULDINGS (DIMENSION) THIN LATERAL/SIDE PROTECTORS+BODY SILL CHROMED DS
WHEEL EMBELLISHER (STYLE) BLACK CAP
EXHAUST TAILPIPE WITHOUT EXHAUST TAIL PIPE
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT) WITHOUT DETACHABLE EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTION DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
EXHAUST TAILPIPE TRIM WITH EXHAUST OUTLET EMBELLISHER
WINDSCREEN GLASS (TYPE) HEATED WINDSCREEN GLASS
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
HEADLAMP WIPER W/O HEADLAMP WIPER
ROOF GLASS WITH SLIDING TILTING ROOF WINDOW ONE-TOUCH CONTROL ANTI-PINCH
BUMPER BODY COLOUR FR BUMPER+GLOSS BLACK GRILLE+BODY COLOUR RR BUMPER+PAINTED BEAD
NUMBER PLATE WITHOUT LICENCE PLATE
FRONT FOGLAMP LED FOG LAMPS + CORNERING LAMP
PANORAMIC VISUAL AID FR PANORAMIC VISUAL ASSISTANCE + RR VISIO PARK 2
SPARE WHEEL WITHOUT SPARE WHEEL
EXTERIOR ACCESSORIES CHROME+BODY-COLOURED EXT HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CURVED EXTERIOR MIRROR GLASS
BUMPER TRIM BUMPER WITHOUT TRIM
GLASS (APPEARANCE) TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN + TOUGHENED REAR GLASS
Interior fittings
SEATING ASSOCIATED VARIANT VARIANT ASSOCIATED WITH HIGH SEAT POSITION
AUDIO PACK AUXILIARY SOCKET 3 USB PORTS
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT 3S
ANTI-THEFT ALARM VOLUME + PERIMETER + LIFT
CIGAR LIGHTER WITHOUT CIGAR-LIGHTER
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT 4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
REAR SEAT SEAT CUSHION+BACK 2/3-1/3 FOLDING
BLIND SPOT DETECTION ACTIVE BLIND SPOT MONITORING
REAR SEAT ARMREST WITH REAR SEAT ARMREST
CABIN SEAT WITHOUT CAB SEAT
LUGGAGE COVER SHELF
ASHTRAY WITHOUT ASHTRAY
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
AIR CONDITIONING WITH HEATER MATRIX
SPEED GRADUATIONS SPEED GRADUATION IN KM/H
GEAR SELECTOR RAISED GEAR LEVER AT THE FLOOR + AT THE STEERING WHEEL
DRIVING POSITION LEFT-HAND DRIVE
ADDITIONAL HEATING AUTO+PGR ADDIT. HEATING(ENG RUNNING+OFF)+REMOTE CTRL
MIRROR LINK WITH MIRROR LINK
LOAD SPACE LIGHTING LED STORAGE COMPARTMENT + GLOVE BOX LIGHTING
DASHBOARD EQUIPMENT ALEZAN NAPPA TWO-TONE LEATHER DECOR
MISC. INT. LAMPS POLYCHROME AMBIENCE LED LIGHTING
INSTRUMENT PANEL (CHARACTERISTICS) DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS
CHILD SEAT ANCHORING POINTS WITHOUT ANCHORAGE WITH ISOFIX FR AND RR
LOUDSPEAKER 4 HP FRONT (2 TW + FR) + 4 HP REAR
PROTECTIVE COVER WITHOUT PROTECTIVE BATTERY COVER
ADDITIONAL BLOWER WITHOUT ADDITIONAL PULSE
POLLEN FILTER WITH POLLEN FILTER + ACTIVATED CARBON
LANE KEEPING MANAGEMENT ASSISTANCE WITHOUT TRAJECTORY CONTROL ASSISTANCE
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT+ELECTRIC FRONT SEAT CUSHION ANGLE
DRIVER SEAT CONTROL DRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT
FRONT PASSENGER SEAT CONTROL PASSENGER’S FR ELEC SEAT CTRL + CUSHION FRONT ADJ
DRIVER SEAT ADJUSTMENT DRIVER’S SEAT TILTING BACK ELECPNE LUMBAR SUPPORT+MEMO
FRONT PASSENGER SEAT ADJUSTMENT TILTING SEAT BACK ELECTROPNEUMATIC LUMBAR SUPPORT+MEMO
FRONT SEAT ARMREST FRONT CENTRAL ARMREST FLOCKED + LEATHER
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBS LED BULB
TRAFFIC INFORMATION READER PREVENTION+TRAJECTORY CENTRING LPA
DISPLAY DGT TOUCHSCREEN+12" DFT DISPLAY
CLOCK ANALOGUE CLOCK
COURTESY MIRROR DRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING
FOOTREST ALU DRIVER’S FOOTREST
OIL GAUGE STD OIL LEVEL INDICATOR
HEATING ELEMENT DRIVER AND PASSENGER HEATED + VENTILATED SEAT ROW 1
FRONT LATERAL AIRBAG FR CHEST/PELVIS SIDE AIRBAG+CURTAIN AIRBAG
FOOTWELL LIGHTING DRIVER + FR PASSENGER FOOTWELL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
EQUIPMENT PACK W/O EQUIPMENT PACK
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER AUTOMATIC HEADLAMP ADJUSTMENT
WIFI WITH WIFI
RADIO RECEIVER DIGITAL CONNECTED NAVIGATION
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL SPEED LIMITER ACC STOP AND GO REGULATOR
DRIVER’S SEAT HEIGHT CONTROL ELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRROR FRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
CARPET COVER CARPET MAT 1
LOAD SPACE STORAGE RETRACTABLE FLOOR STORAGE COMPARTMENT
REAR SEAT PADDING WITHOUT RR PASSENGER DETECTION
TUNER RADIO TRI RADIO TUNER
OBSTACLE DETECTION SYSTEM FRONT-REAR RADAR OBSTACLE SENSOR
TRIM ADAPTATION LEATHER GEAR LEVER KNOB + LEATHER GAITER
FLOOR MAT FR + RR MATS
EQUALISER AMPLIFIER AMPLI EQUALISER WITH PREMIUM 12 CHANNELS
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL CENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEEL SPLIT LEATHER STEERING WHEEL + DECOR
Electrical
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
ALTERNATOR ALTERNATOR ISTT53
HORNS HORNS-HARMONY
BATTERY L3 760 70AH EFBC 760 BATTERY BECOMES EFBC
STARTER MOTOR STARTER MOTOR CLASS 6+
CEN. LOCKING REM CONTROL FREQUENCY 433.92 MHZ SUPER HETERODYNE
ELECTRICAL EQUIPMENT (SUPPLY) STANDARD PROVISION ELECTRICAL EQUIPMENT
BATTERY CHARGER WITHOUT ON-BOARD CHARGER
MULTIPLEXING R3 ECO ELECTRICAL ARCHITECTURE
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENT WITH BATTERY CHARGE MEASUREMENT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
MODIF. DURING MODEL YEAR 6TH MINOR MODIFICATION
CONDENSER (SPECIFICATIONS) CONDENSER 19,3DM2 THICKNESS 12
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL WITHOUT LABEL
AIR CONDITIONING PIPES IHX TECHNOLOGY AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET DOUBLE ACCESSORY SOCKET
SET OF KEYS SET OF BADGE KEYS + BACK-UP KEY
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT PUNCTURE REPAIR KIT
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
P4A 9839102799
General information
SILHOUETTE S.U.V.
ENGINE (TYPE) EW/DW
BADGE WITHOUT BADGE
Fuel supply-Engine
ENGINE (TYPE) EW/DW
CAPACITY 2000 CM3
Body fittings
HORNS HORNS-HARMONY
Interior fittings
LUGGAGE COVER SHELF
WIFI WITH WIFI
Electrical
HORNS HORNS-HARMONY
Miscellaneous
LABEL WITHOUT LABEL
joksa1984
- x 7
Hello,wheeler wrote: 27 Mar 2025, 22:00 Here you go
P4A 9839102799
General information
SILHOUETTE S.U.V.
ENGINE (TYPE) EW/DW
BADGE WITHOUT BADGE
Fuel supply-Engine
ENGINE (TYPE) EW/DW
CAPACITY 2000 CM3
Body fittings
HORNS HORNS-HARMONY
Interior fittings
LUGGAGE COVER SHELF
WIFI WITH WIFI
Electrical
HORNS HORNS-HARMONY
Miscellaneous
LABEL WITHOUT LABEL
One more thing, i am not fully sure about is how to check if my version has "active scan suspension" feature? I do have 2.0 BluHDI, Opera, which should be standard for the trim, but not sure since i cant see it in the list..
