puddles and bubbling around injectors
coatess
x 3
Unread post by coatess »
Hi, I have a Xsara Picasso 2009 diesel with the 1.6hdi 9hx engine. There is a small amount of bright yellow liquid bubbling away around the one of the injectors from when I start the engine from cold, and increases as the engine warms up. Also as the engine warms up, the far left injector area starts to make a chuffing sound. What is going on? Any ideas would be welcome. Thanks :?-?)
coatess
x 3
Re: puddles and bubbling around injectors
Also there is a smell of diesel exhaust fumes inside the car when you put the fan on.
PaulC5
x 682
Unread post by PaulC5 »
Likely the injector to cylinder head seals are leaking. I would not leave it long before fixing since you can end up with a lot of carbon around the injectors making them difficult to remove.
Steve Walsh
x 516
Unread post by Steve Walsh »
Pull injectors out, clean the seats thoroughly , might need a injector reamer to remove carbon, fit new copper seals and torque to the spec. I had a mates 2 litre hdi recenttly that had 2 injectors leaking for a few months and it took me a day with a hammer and chisel to get all the carbon off th head.
coatess
x 3
ok, thank you. I guessed it might be injector seals leaking. Just wasn't confident in my diagnosis.Thank you again.
coatess
x 3
I am going to replace the seals. What tools and materials should I use to clean up around the injectors before I start?
Steve Walsh
x 516
Depends how bad it is, I would use a small brass wire brush about the size of a toothbrush and brake cleaner as a solvent
x 2005
Unread post by Stickyfinger »
