C1 central locking issue
nickhill10
Unread post by nickhill10 »
My fob does not lock or unlock the drivers door, passenger side is fine.
But when I use the key in the drivers door this unlocks the passenger side no problem.
Am I looking a a wiring fault or does the fact that the key works the central locking ok point to something else?
x 1055
Re: C1 central locking issue
Unread post by wheeler »
I'd say check the wiring in in the trunking between the drivers door & body, this is a common place for wire to break as they are being flexed all the time.
PaulC5
x 691
Unread post by PaulC5 »
Looks as if you have had this fault for a year now, did you do anything over the year to try and fix it or try a Citroen dealer ? viewtopic.php?p=795044#p795044
