C4 picasso 2015... help please 🙈!
Tarawhite88
Unread post by Tarawhite88 »
Any advice much appreciated!
Replaced clutch and flywheel last week all fine running great, Tuesday the slave cylinder spat it's dummy out spring clip broke dropping the clutch fluid etc, replaced that yesterday now have an engine fault and handbrake fault sometimes an abs fault, engine fault is clutch master cylinder implausible signal which I've just been to pick up a new master to change it but cant currently get the wipers off to replace it waiting on pullers to come tomorrow! But what we don't understand is you press the clutch to start and get engine fault and nothing won't start, put it into reverse with clutch down and it starts.... any ideas?
C4 picasso 2015 1.6 ehdi.
Thanks in advance
