PEugeot 206 1.4 HDi intake air
peu206
no problem
Arkis
- x 27
Re: PEugeot 206 1.4 HDi intake air
Intake air temperature should be same temperature as outside the car + few degrees of how the air warms up going around hot engine. 95°C is nonsense. I would check wiring from sensor to ECU.
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW, 6 speed manual
Peugeot 206, 2005, 1.4i 8v, 55kW, 4 speed AT
Peugeot 208, 2019, 1.2i PureTech, 61kW, 5 speed manual
Opel Insignia, 2015, 2.0 CDTi, 120 kW, 6 speed AT
Hyundai Santa FE 4WD, 2015, 2.2 CRDi 145 kW, 6 speed AT
peu206
Arkis wrote: 21 Mar 2025, 06:41 Intake air temperature should be same temperature as outside the car + few degrees of how the air warms up going around hot engine. 95°C is nonsense. I would check wiring from sensor to ECU.
You are very kind to always help
But this problem has caught up with me.
