Dpf filter additive too low!
Dunkah
x 11
Unread post by Dunkah »
Hi all,
Had the ‘particle filter additive too low’ warning just come on this evening.
Can anyone tell me how to find out if it’s refillable or the pouch type please
Also, can anyone point me in the right direction for exactly what additive I need and how much of it, thanks.
If anyone can suggest how long I can now drive it for until I get this sorted I’d appreciate it, suppose to go and meet a friend day after tomorrow two hours each direction. I do have another car I can use in the meantime but it’s not especially comfortable.
Thanks all
C5 x7 2ltr hdi 2008
Vin VF7**************[VIN obfuscated, can be read by forum staff]
x 6950
Re: Dpf filter additive too low!
Typically for this age vehicle, you would ned the Infineum F7995 additive (Green Click Fit), but there are universal types now, so have a look here:
https://www.ebay.co.uk/itm/116470420413
They should be able to verify, but you'll likely have a 3 litre tank on the X7. We can't access parts data at present.
If the vehicle doesn't think there's enough fluid remaining between now and the next service interval (see your next service mileage on the instrument cluster) it will flag the warning. Just make sure you minimise short journeys and stop start traffic.
Dunkah
x 11
Thanks Marc.
How do I find the tank and refill it though, can’t see anything under the bonnet that’s obvious for it?
x 6950
It's not that easy, come on! :-D
The additive tank is concealed behind the rear exhaust heat shield (usually the left side), and this has to be removed for access. The tank has click fit unions and is gravity filled using the filling kit. This is only included with the additive sold with filling kits - so if you just bought the solution, you'll have to get one.
Don't forget you'll need to reset the additive counter to zero in order to tell the engine ECU it has been refilled - or you will still get the messages. You'll need Diagbox or another professional level tool to do this.
Dunkah
x 11
I do have a Lexia so that shouldn’t be an issue.
Infineum F7995 Doesn’t seem easy to find at the moment in uk, does it matter if I use something else?
x 6950
See the link in one of my previous posts:
viewtopic.php?p=834037#p834037
Dunkah
x 11
This is the one that’s coming up suitable for my car
https://www.ebay.co.uk/itm/284644319246
Dunkah
x 11
Looking a bit confusing now….. that link you sent comes up as not suitable for my c5, only c5’s listed for it are C5 III 08-18 1.6 E-HDI 1.6 HDI 2.0 BlueHDI
If I select my car it comes up with ‘does not fit’
x 6950
The one from Neo Brothers looks like a generic fluid, so I suggest you just send them your reg to make sure, as some of these are universal fluids, so best to make sure.
Dunkah
x 11
Getting a bit closer now I think, following one looks a bit closer to your suggested spec and lists my car as correct
https://www.ebay.co.uk/itm/186743967726
x 6950
Yes, that's another all-in-one additive that says for all generations, so should be fine.
Dunkah
x 11
Excellent! Thanks Marc, your advice is always appreciated.
