Hello,
Could I possibly I trouble you for a non-UK DS7 Crossback 2022 build sheet? The VIN is VR1**************[VIN obfuscated, can be read by forum staff].
Cheers!
DS7 Build sheet request
- x 1055
Re: DS7 Build sheet request
Vehicle characteristics
Vehicle family DS 7 CROSSBACK (X74)
AS/RP N° 16605 88 1 0453
Warranty Start Date 15/06/2022
Engine serial number 10 Q4EP 0085317
BER e2*2007/46*0601*20
P4A 9831364899
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE DS
VEHICLE FAMILY DS 7 CROSSBACK (X74)
SILHOUETTE S.U.V.
TRIM LEVEL UPPER MEDIUM
ENGINE DV5RC/UE63 1.5 L DIESEL
TRANSMISSION STT TYPE 8-SPEED AUTOMATIC GEARBOX
PAINT TYPE METALLIC LACQUER
BODY COLOUR KCA - ARTENSE GREY PAINT
INTERIOR TRIM TYPE NAPPA LEATHER "4H"
UPHOLSTERY COLOUR "FI"
GEARBOX (CHARACTERISTICS) ATNG8 AUTOMATIC GEARBOX WITHOUT ELECTROMAGNETIC PUMP
CONVERSION GUIDANCE WITHOUT CONVERSION
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) DV TYPE ENGINE
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE FAMILY BADGE
Fuel supply-Engine
DRIVE BATTERY WITHOUT TRACTION BATTERY
FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
FUEL FILLER CAP WITHOUT FUEL FILLER CAP
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 6.3 ENGINE EMISSION CONTROL
SPEED SENSOR SIGNAL FRONT WHEEL SENSOR NON-SIGN RR SIGNED
CAPACITY 1500 CM3
CATALYTIC CONVERTER CATALYTIC CONVERTER BELOW 50PPM
FUEL TANK NON-PRESSURISED FUEL TANK WITH LOCATING TAB
FUEL TANK INSULATION WITHOUT FUEL TANK INSULATION
COOLING MOTOR RADIATOR 28DM2 EP: 18 BRAZED ALU
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) ENGINE POWER 96KW - 300NM
SPECIAL POWER TRAIN SOUND WITHOUT POWER TRAIN ACOUSTICS
EOBD SELF-DIAGNOSIS SYSTEM WITH "OBD" AUTO-DIAGNOSTICS
VEHICLE TECHNICAL DEPOLLUTION EURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
FAN ONE 2-SPEED FAN 140 W DYNAMIC AIR SHUTTER RB45
DRIVE TRAIN INTERNAL COMBUSTION DRIVE TRAIN
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START WITH STOP AND START STARTER
Gearbox Transmission
FINAL DRIVE RATIO FINAL DRIVE RATIO 15 X 58
WHEEL STYLE STYLE3 19 INCH ALLOY WHEEL
CLUTCH WITHOUT CLUTCH
SEAL, WHEEL END WHEEL-SIDE SEAL RZ17.5 D26
SEAL, DIFFERENTIAL END AXLE-SIDE SEAL JB2T D26
RIM/TYRE SIZE 19 INCH TYRE FIT
TYRE (SIZE, TYPE) 235/50 R19 103V REINFORCED
DRIVING WHEELS 2 DRIVEN WHEELS
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR INDIRECT DETECTION OF UNDER-INFLATION WITH LOCATION
GEARBOX TYPE ATN8 TYPE GEARBOX
Suspension-Steering-Brakes
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 18.5
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR STIFFNESS 32500 NM/RAD
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLE WITH STEERING ANGLE SENSOR
SUSPENSION NORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT BOSCH 9.3 ESP
STEERING (OPERATION) LOW POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) PEDAL ALUMINIUM
Body fittings
TOWBAR WITHOUT TOWBAR
HORNS HORNS-HARMONY
SIDE MOULDINGS (TYPE) CHROME SIDE PROTECTORS
SIDE MOULDINGS (DIMENSION) THIN LATERAL/SIDE PROTECTORS+BODY SILL CHROMED DS
WHEEL EMBELLISHER (STYLE) BLACK CAP
EXHAUST TAILPIPE WITHOUT EXHAUST TAIL PIPE
UNDERBODY SHIELD FRONT RIGHT AND FRONT LEFT UNDER-FLOOR LONG DEFLECTOR PROTECTION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT) WITHOUT DETACHABLE EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTION DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
WINDSCREEN GLASS (TYPE) HEATED WINDSCREEN GLASS
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
HEADLAMP WIPER W/O HEADLAMP WIPER
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER BODY COLOUR FR BUMPER+GLOSS BLACK GRILLE+BODY COLOUR RR BUMPER+PAINTED BEAD
NUMBER PLATE WITHOUT LICENCE PLATE
FRONT FOGLAMP LED FOG LAMPS + CORNERING LAMP
PANORAMIC VISUAL AID FR PANORAMIC VISUAL ASSISTANCE + RR VISIO PARK 2
SPARE WHEEL WITHOUT SPARE WHEEL
EXTERIOR ACCESSORIES CHROME+BODY-COLOURED EXT HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CURVED EXTERIOR MIRROR GLASS
BUMPER TRIM BUMPER WITHOUT TRIM
GLASS (APPEARANCE) TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN + TOUGHENED REAR GLASS
HANDS FREE ACCESS AND STARTING WITH HANDS-FREE ACCESS/STARTING
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTER WITHOUT CIGAR-LIGHTER
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT 4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
REAR SEAT SEAT CUSHION+BACK 2/3-1/3 FOLDING
BLIND SPOT DETECTION WITH BLIND SPOT MONITORING
REAR SEAT ARMREST WITH REAR SEAT ARMREST
CABIN SEAT WITHOUT CAB SEAT
LUGGAGE COVER SHELF
ASHTRAY WITHOUT ASHTRAY
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
AIR CONDITIONING WITH HEATER MATRIX
SPEED GRADUATIONS SPEED GRADUATION IN KM/H
GEAR SELECTOR RAISED GEAR LEVER AT THE FLOOR + AT THE STEERING WHEEL
DRIVING POSITION LEFT-HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
MIRROR LINK WITH MIRROR LINK
LOAD SPACE LIGHTING LED STORAGE COMPARTMENT + GLOVE BOX LIGHTING
DASHBOARD EQUIPMENT ALEZAN NAPPA TWO-TONE LEATHER DECOR
MISC. INT. LAMPS MONOCHROME AMBIENCE LED LIGHTING
INSTRUMENT PANEL (CHARACTERISTICS) DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS
CHILD SEAT ANCHORING POINTS WITHOUT ANCHORAGE WITH ISOFIX FR AND RR
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS
PROTECTIVE COVER WITHOUT PROTECTIVE BATTERY COVER
ADDITIONAL BLOWER WITHOUT ADDITIONAL PULSE
POLLEN FILTER WITH POLLEN FILTER + ACTIVATED CARBON
LANE KEEPING MANAGEMENT ASSISTANCE WITHOUT TRAJECTORY CONTROL ASSISTANCE
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT+ELECTRIC FRONT SEAT CUSHION ANGLE
DRIVER SEAT CONTROL DRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT
FRONT PASSENGER SEAT CONTROL PASSENGER’S FR ELEC SEAT CTRL + CUSHION FRONT ADJ
DRIVER SEAT ADJUSTMENT DRIVER’S SEAT TILTING BACK ELECPNE LUMBAR SUPPORT+MEMO
FRONT PASSENGER SEAT ADJUSTMENT TILTING SEAT BACK ELECTROPNEUMATIC LUMBAR SUPPORT+MEMO
FRONT SEAT ARMREST FRONT CENTRAL ARMREST FLOCKED + LEATHER
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBS LED BULB
TRAFFIC INFORMATION READER PREVENTION+TRAJECTORY CENTRING LPA
DISPLAY DGT TOUCHSCREEN+12" DFT DISPLAY
CLOCK ANALOGUE CLOCK
COURTESY MIRROR DRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING
FOOTREST ALU DRIVER’S FOOTREST
OIL GAUGE W/O OIL LEVEL INDICATOR
HEATING ELEMENT DRIVER AND PASSENGER HEATED + VENTILATED SEAT ROW 1
FRONT LATERAL AIRBAG FR CHEST/PELVIS SIDE AIRBAG+CURTAIN AIRBAG
FOOTWELL LIGHTING DRIVER + FR PASSENGER FOOTWELL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
EQUIPMENT PACK W/O EQUIPMENT PACK
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER AUTOMATIC HEADLAMP ADJUSTMENT
WIFI WITH WIFI
RADIO RECEIVER DIGITAL CONNECTED NAVIGATION
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL SPEED LIMITER ACC STOP AND GO REGULATOR
DRIVER’S SEAT HEIGHT CONTROL ELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRROR FRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
CARPET COVER CARPET MAT 1
LOAD SPACE STORAGE RETRACTABLE FLOOR STORAGE COMPARTMENT
REAR SEAT PADDING WITHOUT RR PASSENGER DETECTION
TUNER RADIO TRI RADIO TUNER
OBSTACLE DETECTION SYSTEM FRONT-REAR RADAR OBSTACLE SENSOR
TRIM ADAPTATION LEATHER GEAR LEVER KNOB + LEATHER GAITER
FLOOR MAT FR + RR MATS
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL NORMAL + AUTOMATIC LOCKING
STEERING WHEEL SPLIT LEATHER STEERING WHEEL + DECOR
SEATING ASSOCIATED VARIANT VARIANT ASSOCIATED WITH HIGH SEAT POSITION
AUDIO PACK AUXILIARY SOCKET 3 USB PORTS
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT 3S
Electrical
ALTERNATOR ALTERNATOR CLASS 18 HEA
HORNS HORNS-HARMONY
BATTERY L3 760 70AH EFBC 760 BATTERY BECOMES EFBC
STARTER MOTOR STTD STARTER
CEN. LOCKING REM CONTROL FREQUENCY 433.92 MHZ SUPER HETERODYNE
ELECTRICAL EQUIPMENT (SUPPLY) STANDARD PROVISION ELECTRICAL EQUIPMENT
BATTERY CHARGER WITHOUT ON-BOARD CHARGER
MULTIPLEXING R3 ECO ELECTRICAL ARCHITECTURE
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENT WITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
MODIF. DURING MODEL YEAR 2ND MINOR MODIFICATION
CONDENSER (SPECIFICATIONS) CONDENSER 19,3DM2 THICKNESS 12
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL WITHOUT LABEL
AIR CONDITIONING PIPES IHX TECHNOLOGY AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET DOUBLE ACCESSORY SOCKET
SET OF KEYS SET OF BADGE KEYS + BACK-UP KEY
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT PUNCTURE REPAIR KIT
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
P4A 9831364899
General information
SILHOUETTE S.U.V.
BADGE FAMILY BADGE
Fuel supply-Engine
CAPACITY 1500 CM3
Body fittings
HORNS HORNS-HARMONY
Interior fittings
LUGGAGE COVER SHELF
WIFI WITH WIFI
Electrical
HORNS HORNS-HARMONY
Miscellaneous
LABEL WITHOUT LABEL
Dagman
Hi, How do I go about requesting a build sheet for my ds7 crossback. I have the vin number but how do I submit that? Thanks.
PaulC5
- x 693
Just put the VIN in your post, it will be hidden to all apart from admin.
Dagman
Thankyou so much, the number is VR1**************[VIN obfuscated, can be read by forum staff]
Keen to know what it has/hasn't been supplied with! Cheers.
- x 1055
Here you go
AS/RP N° 16193 88 1 0008
Warranty Start Date 30/10/2021
Engine serial number 10 FKBL 2765336
OPB 00I5
BER e2*2007/46*0601*17
P4A 9837598299
General information
SILHOUETTE S.U.V.
ENGINE EP6FADTXD/EU63 1598 PETROL
BODY COLOUR KTV - BLACK PEARL PAINT
ENGINE (TYPE) EP TYPE ENGINE
BADGE FAMILY BADGE
Fuel supply-Engine
FUEL UNLEADED PETROL 95 QUALITY A/B/E/E+
CAPACITY 1600 CM3
FUEL TANK FUEL TANK WITHOUT LOCATING TAB
COOLING MOTOR RADIATOR EP28 28DM2 BRAZED ALUMINIUM
FAN 1ELECT VARIABLE SPEED 180W AERO DYNAMIC FLAP
FINAL DRIVE RATIO REAR AXLE GEARSET 15 X 61
WHEEL STYLE STYLE5 20 INCH ALLOY WHEEL
RIM/TYRE SIZE 20 INCH TYRE FIT
TYRE (SIZE, TYPE) TYRE 235/45 R20 100V NON-REINFORCED
REAR ANTI-ROLL BAR ANTI-ROLL BAR DIAM 19
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
STEERING (OPERATION) HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING
Body fittings
HORNS HORNS-HARMONY
EXHAUST TAILPIPE REAR RIGHT AND LEFT EXHAUST OUTLET
EXT. LOAD RETENTION RING (ATTACHMENT) BOAT EXT LASHING RING
EXHAUST TAILPIPE TRIM CHROME EXHAUST OUTLET TRIM
PANORAMIC VISUAL AID WITH REAR PANORAMIC VISUAL ASSISTANCE VISIO PARK1
HANDS FREE ACCESS AND STARTING AVEC ACCES ET DEMARRAGE MAINS LIBRES
Interior fittings
ANTI-THEFT ALARM VOLUME + PERIMETER + LIFT
LUGGAGE COVER SHELF
CLIMATE (AMBIENT TEMP) HOT OR WIDER TEMPERATE COUNTRY
SPEED GRADUATIONS SPEED GRADUATION IN MPH
DRIVING POSITION RIGHT HAND DRIVE
OIL GAUGE STD OIL LEVEL INDICATOR
WIFI WITH WIFI
LOCKING CONTROL CENTRAL DEADLOCKING + AUTOMATIC LOCKING
Electrical
ALTERNATOR ALTERNATOR CLASS 15 UHEA
HORNS HORNS-HARMONY
Miscellaneous
SPECIAL SPECIFICATION MECCANO 14
LABEL WITHOUT LABEL
OPB 00I5
P4A 9837598299
General information
SILHOUETTE S.U.V.
BADGE FAMILY BADGE
Fuel supply-Engine
CAPACITY 1600 CM3
Body fittings
HORNS HORNS-HARMONY
Interior fittings
LUGGAGE COVER SHELF
WIFI WITH WIFI
Electrical
HORNS HORNS-HARMONY
Miscellaneous
LABEL WITHOUT LABEL
Dagman
Thankyou wheeler, much obliged.
Dagman
Hi guys, can anyone enlighten me? The data for my car above shows heated windscreen glass, so does that mean it defrosts across the whole screen like my Ford C-Max? And where on earth is the method to switch it on? It is an Opera trim. I don't get the ds7 until Wednesday, and still trying to work out what I have. The myds app just lists "all" ds7 stuff and leaves you to wonder what applies to your car (not saying Opera has this or performance+ has that, frustrating.) Thanks.
Dagman
I don't even know if it has active scan suspension, I know, should have checked all this on the test drive but there was so much to take in. It has Eagle summer tyres all round but one was an oddball never heard of on the rear. So they are putting matching Goodyear all seasons on the back instead (I don't like summer rated, useless in winter) I will soon get the same ones for the front, not keen on the mix but better the all seasons on rear for now.
Dagman
Anyone know about the heated windscreen? Is it the whole screen? Thanks.
PaulC5
- x 693
At a guess you could wet the windscreen and put the heater on and see if it dries across it or just touch it to see if it is warm. There might also be something in the handbook.
Dagman
Thanks paulC5, I Don't get the car until Wednesday, it is a 2021 petrol, I've downloaded the manual, there is a button to the right of the driver symbolising a windscreen with a zigzag across but nothing tells me if it's the entire screen or just the left near the pillar where the French drivers would benefit. As you say could see if it evaporates water or just wait until it's a frosty day. A shame if it is ineffective. Hope someone has this model and knows. Cheers.
PaulC5
- x 693
I would think it is the full screen, driving with a partially cleared windscreen is probably not legal.
Itswhitty7
- New User
Hi there how do i get the build sheet for my ds7 cheers vin is VR1**************[VIN obfuscated, can be read by forum staff] if that helps.
Thanks in advance
Thanks in advance
Vargur
Hello guys,
I'm the happy owner of a 2019 DS7 Rivoli spec since August, however, with winter approaching, I'm starting to wonder if my car has heated front seats.
I do not see any digital or physical buttons anywhere related to this, and eventually apparently I'd have to check the F7 fuse in the box to make sure it's functional.
I've tried different sites and I did not find one which can provide me with a list of equipment for VIN VR1**************[VIN obfuscated, can be read by forum staff].
