Battery failure
Sim Yen Chuan
Battery failure
Unread post by Sim Yen Chuan »
Own a Peugeot 2008 with encounter 2 times battery failure during this 2 year without any warranty replacement.
Arkis
x 27
Re: Battery failure
Unread post by Arkis »
What did the dealer said about it? Is there any parasitic draw? Are you leaving accesories running or something? Maybe waiting for somebody with engine turned off and listening to radio or something like that?
Is alternator charging?
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW, 6 speed manual
Peugeot 206, 2005, 1.4i 8v, 55kW, 4 speed AT
Peugeot 208, 2019, 1.2i PureTech, 61kW, 5 speed manual
Opel Insignia, 2015, 2.0 CDTi, 120 kW, 6 speed AT
Hyundai Santa FE 4WD, 2015, 2.2 CRDi 145 kW, 6 speed AT
Sim Yen Chuan
Re: 2008 (Battery failure)
As U R mentioned as an above diagnostic, non of it Ur comment is correct.
I just leave my car for 2 days without start my engine. Third days the battery was flat.
Sim Yen Chuan
This battery failure not only happening in the first time. This was happened 2 years for 2 times. After workshop diagnostics found a battery failure or flat.
Request for replace a new battery, but workshop reluctant to replace my battery said the warranty was over 2 year.
My question: Peugeot original battery can only last for one year?
x 2938
Re: Battery failure
You need a proper auto electrician to diagnose the fault there are quite a few possibilities faulty alternator (diodes) after market alarms and stereo equipment, faulty door and tailgate locks, even corroded battery terminals, an electrician will find the problem quite quickly.
Your climate in Malaysia may dictate how long a battery will last but I'd expect it to be at least four or five years.
Sim Yen Chuan
Re:2008 Battery failure
Appreciated your comment for Peugeot original battery can last at least 4 to 5 year..
Now, I need French Peugeot help to inform at our local Peugeot branch to replace my battery.
Because this branch said my battery warranty was over.
Sim Yen Chuan
I purchased this car for model 2008 in a year of 2022 with encounter 2 times battery failure.
I leave in Penang Malaysia own a car registration number QS2228Q.
I complaint this issue is require Peugeot workshop properly diagnostics my car again n replaced my faulty battery.
