I have a Jumpy 2.0 I4 2012 that after i got DPF warning the gears stopped working. I cant get it in any gear. I push down the clutch but when i put it in gear nothing happends. I sounds and feels like it its in gear but its stuck in neutral. No other warning lights except the DPF.
Any suggestions? Thanks. Can DPF Low indicator mess up the gears?
Rgds
Bjorn
Gear stop working Jumpy 2012 2.0
Hadida
Re: Gear stop working Jumpy 2012 2.0
Hi Bjorn
Sorry you have to have 2 problems at once. The DPF should trigger limp mode after a number of kms. The gear selection sounds like a linkage/bush problem. Check your linkage connections. DPF will require a clean or long highway drive @ 100km/h .
