peugeot 106 quick no spark
relax88
Unread post by relax88 »
Hello, I recently bought a 106 for short-term use. I was able to use it for 2-3 days, but then the vehicle started to malfunction.
There is no ignition in the vehicle at the moment, it's like a joke, but the crank sensor, the red double relay and finally the brain were changed.
ignition coil and spark plugs are intact This situation occurred as a result of a short circuit, I think there was a burn in a cable but we could not find it.
Could you please help me with which cables could be causing this problem?
Could it be grounding or I need any ideas you can think of, thank you
