Service information
RoosterBooster
Service information
Unread post by RoosterBooster »
Getting ready for my first servicing of a 2013 plate 207SW (VIN: VF3**************[VIN obfuscated, can be read by forum staff]) and I'm looking to confirm the correct oil specification for the engine.
The Warranty & Maintenance Record booklet suggests either PSA B71 2290 (recommending Total Activa or Total Quartz INEO ECS 5W-30) or PSA B71 2312 (recommending Total Quartz INEO First 0W-30) would be acceptable for a 1.6 HDi FAP engine.
Would any brand satisfying 2290 or 2312 be suitable? For example, Millers Oils Trident Professional C2/C3 5w30 claims to satisfy 2290.
And out of curiosity, what is the correct engine code? I've seen the 68kW engine (which is what is stated on the V5C) reported as DV6D but I've also seen other codes.
Thanks in advance.
PaulC5
x 696
Re: Service information
Unread post by PaulC5 »
I have always used the recommended Total oils, they are cheap enough through ebay sellers. INEO ECS 5W-30 for the C5 and INEO First 0W-30 for the cactus.
x 6945
RoosterBooster wrote: 13 Mar 2025, 21:37 Getting ready for my first servicing of a 2013 plate 207SW (VIN: VF3**************[VIN obfuscated, can be read by forum staff]) and I'm looking to confirm the correct oil specification for the engine.
Thanks in advance.
The following are the official recommended oils for your vehicle:
05W30 B71 2290 (C2) - EM:00W30 B71 2312 - EM:05W30 B71 2290 - 00W30 B71 2312 (C1C2)
Your engine code is a DV6DTED (Euro 5)
In case you have further questions about the build, here is your build sheet:
Vehicle Characteristics
Vehicle family207
AS/RP N°13161 82 1 0030
Warranty Start Date13/02/2013
Engine serial number10 JBFM 0006267
BERe2*2001/116*0340*26
P4A9802314999
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPEPEUGEOT
VEHICLE FAMILY207
SILHOUETTE5 DOOR ESTATE
TRIM LEVELRUN OUT
ENGINETURBO DIESEL DV6DTED
TRANSMISSIONBVM5
PAINT TYPENON-METALLIC PAINT
BODY COLOURKKN - PAINT ADEN RED
INTERIOR TRIM TYPEW&W CHILICO+MAILHORSPISTE+F915 "4D"
UPHOLSTERY COLOUR"FX"
GEARBOX (CHARACTERISTICS)BE4-5L MANUAL GEARBOX
ENGINE (TYPE)DV TYPE ENGINE
ROOF (EXT. ASPECT)BODY COLOUR ROOF
OTHER BADGE, " MISC. "WITHOUT FULLER BADGE
BADGEWITHOUT BADGE
TRIM LEVELRUN OUT
STEERINGPOWER STEERING
SPEEDOMETER DRIVEW/O TACHO TORQUE
Fuel Supply-Engine
FAN1 AERO 2-SPEED 140W FAN WITH SCOOP
FUEL VAPOUR RETRIEVALWITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANTMOUNTING BOSCH
TANK FILTERCITHOUT RESERVOIR FILTER
STOP AND STARTWITHOUT STOP AND START
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL)CRANKCASE ALUMINIUM
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 5 L6 UPPER ENGINE EMISSION CONTROL
SPEED SENSOR SIGNALMULTIFUNCTIONAL ACTIVE SENSOR
CAPACITY1600 CM3
CATALYTIC CONVERTER2 FILTERING COMPONENTS IMPREGNATED WITH PLATINUM+PADIUM 40G
OIL COOLERWITHOUT OIL COOLING
FUEL TANKFUEL TANK WITH LOCATING TAB
OPTIMISATION OF VEHICLE’S CONSUMPTIONFUEL CONSUMPTION OPTIMISATION
COOLING MOTORRADIATOR TH : 18 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)PUISSANCE 68 KW 230 NM
VALVE PER CYLINDER2
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
DEVICE (ANTIPOLLUTION)"EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTIONTECHNICAL VEHICLE EMISSION CONTROL EURO 5
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
Gearbox Transmission
GEARBOX TYPEGEARBOX BE4R
TRANSMISSIONBVM5
FINAL DRIVE RATIOREAR AXLE HYPOID GEARSET 17 X 61
WHEEL STYLECANBERRA 16"
CLUTCHHYDRAULIC CLUTCH
SEAL, WHEEL ENDWHEEL-SIDE SEAL RZ 17.5
SEAL, DIFFERENTIAL ENDAXLE-SIDE JOINT JB2A
DIFFERENTIAL (GEARBOX)DIFFERENTIAL 84
RIM/TYRE SIZE16 INCH TYRE FITMENT
TYRE (SIZE, TYPE)195/55 R16 87V NON REINFORCED TYRE
DRIVING WHEELS2 DRIVEN WHEELS
WHEELS FITTED6" RIM ROAD WHEELS
WHEEL (TYPE)ALLOY WHEELS
INFLATION PRESSURE LOSS INDICATORWITHOUT TYRE DEFLATION INDICATOR
Suspension-Steering-Brakes
BRAKE ASSOCIATED VARIANTABS TEVES MK70
STEERING (OPERATION)ELECTRIC POWER STEERING
ELECTRIC STEERING80 AMP ELECTRIC STEERING
PEDAL BRACKET (TYPE)PEDAL STANDARD
ABSWITH ABS BRAKES
FRONT ANTI-ROLL BARFRONT ANTI-ROLL BAR DIAM 22
BRAKE TYPEVENTILATED FRONT DISCS/REAR DRUMS
STEERING TRAVELSTEERING MECHANISM TRAVEL 72
SUSPENSIONNORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMWITHOUT ELECTRONIC STABILITY PROGRAM
Body Fittings
HANDS FREE ACCESS AND STARTINGNO ACCES AND HANDSFREE STARTING
TOWBARWITHOUT TOWBAR
HORNSHORN STANDARD
AERIALSHORT ROOF AERIAL
OPENING ROOF (APPEARANCE)WITHOUT SUN ROOF
PAYLOADNORMAL PAYLOAD
FINISHER (SELF-ADHESIVE)MATT BLACK REAR SURROUND TRIM
REAR SPOILERASSEMBLY WITHOUT REAR SPOILER
SIDE MOULDINGS (TYPE)SIDE PROTECTORS BODY COLOUR + CHROME
SIDE MOULDINGS (DIMENSION)WITHOUT LATERAL PROTECTORS
WHEEL EMBELLISHER (STYLE)WITHOUT WHEEL CAP
UNDERBODY SHIELDPLASTIC PROTECTIO + FOAM UNDER ENGINE
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
GUTTER SEALWITH DRIP MOULDING SEAL
EXT. LOAD RETENTION RING (ATTACHMENT)WITH DETACHABLE EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTIONEXT MIRROR ELECTRIC-FOLD BACK
EXHAUST TAILPIPE TRIMW/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFINGBONNET SOUNDPROOFING + THERMAL PROTECTION
WINDSCREEN WIPERFRONT WIPER BLADE W/O RAIN SENSOR
HEADLAMP WIPERW/O HEADLAMP WIPER
REAR SCREEN WIPER (OPERATION)AUTO INTERMITTENT RR WIPER IN REVERSE GEAR
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITH ROOF WINDOW
REAR TAILGATE GLASSFIXED TAILGATE WINDOW
OUTSIDE TEMPERATURE SENSORWITH EXTERIOR TEMPERATURE SENSOR
BUMPERBODY COL SPORT FR BUMPER BODY COL STD RR ALU GRILL
NUMBER PLATEWITHOUT LICENCE PLATE
LUGGAGE RACKMOUNTING WITH ROOF BARS
FRONT FOGLAMPFRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC)DOUBLE OPTIC LAMPS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE)DRIVER’S DOOR MIRROR ELECTRIC CONTROL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE)PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
SPARE WHEELSTEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIESBODY COLOURED EXT HANDLES + EXT MIRROR
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)CURVED EXTERIOR MIRROR GLASS
SUN ROOFFIXED ROOF
BODY CONVERSIONWITHOUT
BUMPER TRIMDYED BUMPER STRIP
GLASS (APPEARANCE)TINTED
REAR QUARTER WINDOW (TYPE)FIXED REAR QTR GLASS
WINDOW (TYPE)LAM W/SCREEN + SIDE + RR TOUGHENED
Interior Fittings
STORAGE SPACE LOCKSGLOVE-BOX WITHOUT LOCKING
AMBIENCE PACKWITHOUT AMBIANCE PACK
DRIVER’S KNEE AIRBAGWITHOUT DRIVER’S KNEE AIRBAG
CHILD OBSERVATION INTERIOR MIRRORWITHOUT INTERIOR CHILD MONITORING MIRROR
AUDIO PACK AUXILIARY SOCKET1 JACK SOCKET + USB + BLUETOOTH
TELEMATIC UNITWITHOUT TELEMATIC UNIT
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTERWITHOUT CIGAR-LIGHTER
REAR HEAD RESTRAINTREAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINTFRONT HEADREST ADJUSTABLE
REAR SEATSEPARATE FOLD BACK BENCH SEAT
LUGGAGE COVERSCREEN
REAR SEATBELT3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
FRONT SEATBELTRETRACTOR ALARM DRIVER + PASS S/BELT
CLIMATE (AMBIENT TEMP)TEMPERATE COUNTRIES
AIR CONDITIONINGAIRCON WITH MOTORISED AIR INLET
CHILD LOCKELECTRIC REAR CHILD LOCK
SPEED GRADUATIONSSPEED GRADUATION IN MPH
GRAB HANDLESFR + RR HANDLES WITH HOOKS
RADIO EQUIPMENTFEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
DRIVING POSITIONRIGHT HAND DRIVE
REMOTE CONTROLREMOTE CONTROL ASSEMBLY
AIR EXTRACTORVENT - STANDARD AIR EXTRACTOR
LOAD SPACE LIGHTINGGLOVE-BOX LIGHTING
DASHBOARD EQUIPMENTLION GREY LION GREY DECORATION SOFT FASCIA
MISC. INT. LAMPSMAP READING LAMP
LOAD SPACE TRIMBOOT CARPET MAT
INSTRUMENT PANEL (CHARACTERISTICS)GRAD 220 KM/H 140 MPH WHITE BACKGND CHROME CIRCLE
LOUDSPEAKER4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
TIMERWITHOUT TACHOGRAPH
RADIO CONTROLSREMOTE RADIO CONTROL
SIDE DOOR CONTROL MECHANISMWITHOUT SIDE DOOR CONTROL
POLLEN FILTERWITH POLLEN FILTER
PASSENGER COMPARTMENT SOUNDPROOFING5KG BULKHEAD SOUNDPROOFING
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT
DRIVER SEAT CONTROLDRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROLPASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENTRECLINING DRIVER’S SEAT BACK
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER TILTING BACK
FRONT PASSENGER SEAT FOLDINGW/O FOLDING PASS FRONT SEATING
FRONT SEAT ARMRESTASSEMBLY WITHOUT FRONT ELBOW REST
ROOF CONSOLESTANDARD ROOF CONSOLE
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMWITHOUT NAVIGATION SYSTEM
HEADLAMP BULBSHALOGEN BULB
REAR WINDOW LIFTMAN CTRL REAR WINDOW LIFTER
DRIVER’S WINDOW LIFTSEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFTSEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
DISPLAYDISPLAY (RADIO+CLOCK AND OR TEMP, CD)
CLOCKNUMERIC CLOCK
MISC. INT. ACCESSORYWITHOUT MISCELLANEOUS INTERIOR ACCESSORIES
COURTESY MIRRORDRIV OCCULT+PASS OCCULT W/O LIGHT
CUSHION PADDINGPADDING WITHOUT PASSENGER DETECTION PAD
OIL GAUGESTD OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGLATERAL AIR BAG
FOOTWELL LIGHTINGWITHOUT DOOR SILL LIGHTING
PASSENGER AIRBAGPASSENGER AIRBAG
ON-BOARD COMPUTERCOMPUTER
EQUIPMENT PACKW/O EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED)HEATED DOOR MIRROR
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE)LION GREY LOOK INTERIOR DOOR HANDLE
COURTESY LAMPDOORS + FR AND RR COURTESY LIGHTS REMOTE CONTROL
REAR LOAD FLOORWITHOUT REAR LOAD FLOOR
DIRECTIONAL HEADLAMPWITHOUT DIRECTIONAL LIGHTS
FRONT SEAT GUARDWITHOUT SEPARATION GRILLE
FRONT SUN VISORDRIVER + PASSENGER SUN VISOR WITHOUT INSCRIPTION
STORAGE (DRIVING POSITION)LOWER GLOVEBOX WITHOUT COOLING
RADIO RECEIVERAUDIO CD SYSTEM RDS "RD45" MP3
REFRIGERATIONSINGLE AIR CONDITIONING
CRUISE CONTROLREGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROLPARALLEL DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRRORNON-ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
STORAGE (OTHERS)W/O OTHER SETTING BOXES
CARPET COVERW/O CARPETMAT
DRIVER AIRBAGDRIVERS AIR BAG
LOAD SPACE STORAGEW/O BOOT TIDY
TUNER RADIOMONO RADIO TUNER
INTERIOR PROTECTIONWITHOUT INNER PROTECTION
EXTERIOR TEMPERATURE (SCALE)EXT TEMP INDICATOR CELSIUS
WATER TEMP INDICATORWATER TEMPERATURE GAUGE INDICATOR_GRADUATED RECEIVER
OBSTACLE DETECTION SYSTEMOBSTACLE DETECTOR
TRIM ADAPTATIONGEAR LEVER KNOB CHROME INSERT
FLOOR MATW/O CARPETMAT
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLCENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEELLEATHER STEERINGWHEEL
Electrical
ALTERNATORALTERNATOR 150 AMP
HORNSHORN STANDARD
BATTERYBATTERY L2 640
STARTER MOTORSTARTER MOTOR CL 4
SPECIAL LIGHTINGWITHOUT PARTICULAR LIGHT
CEN. LOCKING REM CONTROL FREQUENCYLOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
MULTIPLEXINGMULTIPLEXING ASSEMBLY CAN CAN
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
MODIF. DURING MODEL YEARWITHOUT MINOR MODIFICATIONS
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
RADIO HEADPHONE SOCKET12 V FR + RR ACCESSORIES SOCKET
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTSSTANDARD SIDE BUMPERS
SET OF KEYS2 HF PLIP KEYS
DOOR SEALWITHOUT SEAL DIRT EXCLUDER
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
SURFACE CONDITIONSGOOD TERRAIN
SPEED MONITORINGWITHOUT SPEED CHECK
ADDITIONAL TYPE APPROVAL PLATEW/O ADDIT HOMOLOGATION PLATE
SLAVE CONTROL UNITBSI + COM 2005 4-POSITION RING
RoosterBooster
GiveMeABreak wrote: 14 Mar 2025, 09:22 The following are the official recommended oils for your vehicle:
Thanks for the oil advice and confirming the engine code.
Off to the motor factors.
x 6945
For guidance on the standards, check out my thread here, but the above info I provided already is the current and correct data as of yesterday (as they often change these and for this reason I no longer update the the thread with the oil types):
viewtopic.php?t=75918
