Citroen relay 2019 blue hdi chassis cab , one rear light out
jak212
Unread post by jak212 »
bulb is good , not sure which fuse is for rear lights as cant find that info, Or wether the rear lights are even on seperate fuses as one of them works fine,
If I live across from other light in cluster it lights up fine so is a live fault, every other light on van works fine no rust corrosion etc on connectors the lamps or holders , Any suggetions would be appreciated.
Thank you
