My car is disabled(RPM Limit)
peu206
Unread post by peu206 »
I have been struggling with this problem for several months, almost a year. #-o (peugeot 206 1.4 HDI 2006)
I have a constant error code p1352, and the car is locked up and won't go above 3000 rpm,
It has many new parts but the error still exists
no smoke, starts easily,
Can you guys help?
Thanks.
PaulC5
x 697
Re: My car is disabled(RPM Limit)
Unread post by PaulC5 »
peu206
this option did not help
x 1076
Unread post by Rp0thejester »
What do you mean by 'locked up'? How long have you had the car? Any warning lights on the dashboard? Any other error codes?
peu206
The check engine light is off. No other error codes.
I have had the car for 2 years.
x 2938
Rp0thejester wrote: 12 Mar 2025, 22:06 What do you mean by 'locked up'? How long have you had the car? Any warning lights on the dashboard? Any other error codes?
Does he mean 'in limp mode'?
:wink:
peu206
Yes
x 1076
Well first thing I would do is disconnect the battery, that might work, next thing would be the knock sensor if it has one. If that doesn't work I'd be looking at turbo or exhaust issue that's not sending the info back to the ECU.
Sloppysod
x 397
Unread post by Sloppysod »
Could it be a clogged particulate filter? - if it is drive as 50mph for about 20 mins or so, turn off and restart, see if its the same again.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
PaulC5
x 697
Being a 2006 hdi it might not have a dpf in the exhaust.
peu206
I think it's time to check the injection and clean the intake manifold?!
: Cylinder 1 injection ratio 0.02 (it doesn't go up even when you give it gas) Cylinder 2 0.34 (I think this is good) Cylinder 3 0.16 Cylinder 4 -0.64 (also bad)
These are idle values
peu206
Sloppysod wrote: 15 Mar 2025, 12:37 Could it be a clogged particulate filter? - if it is drive as 50mph for about 20 mins or so, turn off and restart, see if its the same again.
It doesn't have a particulate filter,
Arkis
x 27
Unread post by Arkis »
P1352 is code related to glow plugs or relay module controlling the plugs. Are these two circuits working proplely? Isn't some cable shorted (check continuity)? Fuse blown? Also try cleaning grounding points and all connectors and then do BSI reset.
The limp mode (not going over 3000 rpms) is not the problem itself. It's the car trying to minimalize the damages caused by the problem.
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW, 6 speed manual
Peugeot 206, 2005, 1.4i 8v, 55kW, 4 speed AT
Peugeot 208, 2019, 1.2i PureTech, 61kW, 5 speed manual
Opel Insignia, 2015, 2.0 CDTi, 120 kW, 6 speed AT
Hyundai Santa FE 4WD, 2015, 2.2 CRDi 145 kW, 6 speed AT
peu206
Arkis wrote: 17 Mar 2025, 13:30 P1352 is code related to glow plugs or relay module controlling the plugs. Are these two circuits working proplely? Isn't some cable shorted (check continuity)? Fuse blown? Also try cleaning grounding points and all connectors and then do BSI reset.
Thanks, I've checked all of these and they're fine.
However, I don't know how to reset the BSI,
Arkis
x 27
Here is the tutorial for BSI reset. I think it won't help, but hey, at least it's free. :lol:
viewtopic.php?t=61997
