Hello, I had a problem with the belt, as it snapped. I replaced the tensioners and serviced the alternator by changing the bearings and installing a new belt. Now, my car is showing the error message “Check Engine - Repair is Needed,” and after a few kilometers, the belt snapped again.
What could be the cause of this issue? Has anyone had a similar experience, and how did you resolve it?
Thanks in advance for help!
Ds 5 Hybrid 4 Belt issue
- x 1472
Re: Ds 5 Hybrid 4 Belt issue
Welcome
You need to scan it to find out what is causing the error. The belt should be fairly obvious, something must be seized or running out of true.
