Peugeot 508 Hybrid4 oil for rear differential and gearbox
Doom
x 13
Unread post by Doom »
Hello,
Just a quick question, do anyone know what kind of oil should I use as replacement for Peugeot 508 Hybrid 4 for rear differential and gearbox? I heard from local dealership that this is lifetime oil, they don't recommend replacing. As I understand I should wait till gearbox end it's life ;) Every oil degrades. Additionally where can I find screw/hole to fill the oil?
I'll reply myself:
I'll use Total Traxium gear 9 75w80 for rear differential, same for gearbox. For the hydraulic actuator I'll use Ravenol GHA-F
Diffidati
Re: Peugeot 508 Hybrid4 oil for rear differential and gearbox
Unread post by Diffidati »
Hello, can you help me, please. I need to replace the rear differential searing on my 508 RXH, it leaked some oil. Where should I add oil to the differential, I didn't found it? and is there any special procedure for all that?
Vetal88
Unread post by Vetal88 »
Doom wrote: 08 Mar 2025, 21:38 Total Traxium gear 9 75w80 for rear differential, same for gearbox. For the hydraulic actuator I'll use Ravenol GHA-F
Do you mean Total Traxium gear 8 75w80 or Total Traxium gear 9 75w90 ?
