Reverse ECU on DS5
Ds5 airdream
Reverse ECU on DS5
Unread post by Ds5 airdream »
Has anyone ever changed the reverse sensors ECU in the boot and should it work straight away or does it need to be re programmed because I have changed mine and it still doesn't work? Any information please.
x 6957
Re: Reverse ECU on DS5
You can't just replace it, these need configuring for the correct type of assistance.
Specifically, whether front parking assistance is present or not and the type of gearbox fitted (Automatic or Piloted / Manual), there may also be other options for later models.
Djandree
x 38
Unread post by Djandree »
You should be able to configure this ecu using diagbox 7.55/7.57
