Hi guys, picked up a 308 gt line 2015 a few weeks ago, and the last week or so I can hear what sounds like a rolling clunking noise which is more prominent at lower speeds than higher ones. I can't for the life of me figure out what it is. Any ideas?
Car is currently sat at just under 70k, checking the MOT history it failed at 60k due to
Nearside Front Anti-roll bar linkage ball joint excessively worn (5.3.4 (a) (i))
Which I assume had been fixed.
It then had some advisories
Offside Front Suspension arm pin or bush worn but not resulting in excessive movement Rear bush (5.3.4 (a) (i))
Nearside Front Suspension arm pin or bush worn but not resulting in excessive movement Rear bush (5.3.4 (a) (i))
Could it be any of these advisories that are the issue?
Also, when going over speed bumps that look like the pic attached if I go directly over them the front underside of my car seems to scrape them!? Which is now scuffed, I have to go over them at an angle to avoid this, I have no idea if the previous owner had the car lowered or not, how would I find this out? And could this potentially be causing the noise due to the potential suspension change?
It's very annoying.
Rolling clunking noise 308 GT line
JamieLeeWV
PaulC5
- x 698
Re: Rolling clunking noise 308 GT line
Did you sort the bonnet not locking by dropping it from about 12 inches ?
Just asking about this since you have not replied to your previous topic.
JamieLeeWV
Yes sorry that issue has been sorted bud.PaulC5 wrote: 06 Mar 2025, 10:51 Did you sort the bonnet not locking by dropping it from about 12 inches ?
I have also attached a video of the clunking/knocking issue I'm now getting which sounds like it's coming from the front of the car. Any ideas?
