footwell flood
meexi
footwell flood
Unread post by meexi »
Woke up this morning after the downpour to discover a big pool of water in the passenger footwell. Does anyone know where i should start to look for this leak?
1999 xantia hdi estate
Meexi
crooser
Unread post by crooser »
OUTSIDE.no only kidding.you will probably have to check the normal places ie,windscreen surround,scuttle and rear door surround.you may be lucky and find that you left a window open a minute fraction.
davethewheel
Unread post by davethewheel »
i had exactly the same problem and was coming from around scuttle, the panel around the wipers its a plastic trim and the water was leaking underneath it, just sealed it with clear silicon no problems now, its a common problem if its had the windscreen replaced.
sooty
Unread post by sooty »
I not sure what drains your model has but a few things to check as on some cars.
1) If you have a sun roof that slides and tilts, then check that the drain holes and tubes are not blocked, found in the corners of the roof going down to the base of the car.
2) Again as mentioned some cars have a drain grommet or hose from the scuttle areas, check that they are not blocked with leaves etc.
Kowalski
Unread post by Kowalski »
I had this same problem, wet carpets in the footwells, it was caused by the drains in front the windscreen being filled with leaves. Emptied the drains using a vacuum cleaner (my mothers vacuum cleaner is now filled with wet leaves) now everything is dry.
ItDontGo
Unread post by ItDontGo »
If it was mine I'd drill a hole in the floor and sell it. I suppose some people have morals though!
farnellp
Unread post by farnellp »
I have the same problem with my Xantia, but the water comes in through the door, presumably entering where the glass meets the (rather worn) rubber seal. It gets into the footwell from the bottom of the door, between the door and the seal. Check to see if you can see water weeping in at the top of the sill.
I dont have a fix for it though, just a mop ;-)
Regards,
Pete
rossnunn
Unread post by rossnunn »
if your clearing leaves from the scuttle, check the inner wing too, just unscrew the back of the front wheel arch and put your hand inside have a feel about and check there's no leaves stuck there.
Also mind the alarm!!
paranoid
Unread post by paranoid »
Did that don't feel nice[:D][:D][:D][:D][:D]
debutant
Unread post by debutant »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by davethewheel</i>
The scuttle won't ever cause that much water in the footwell.Look for the obvious ... on the passenger side, underneath the scuttle there is a drain to get the water out. What often happens is that leaves and other stuff accumulates there!. I broke a part out of my scuttle so I could easy reach with my hand and get the leaves etc. out. Since then I never saw water again inside the car!
Cheers,
John
