Xantia (1993 td) cigarette socket NO Power
x 1968
Unread post by Stickyfinger »
F16 is live
Earth to the socket is good
Light on the socket works (so earth is good)
No power to the red power lead on .... key OFF -- key AC -- car running
Connectors are good, wire seem fine.
Am I missing something ?
x 1431
Re: Xantia (1993 td) cigarette socket NO Power
Stickyfinger wrote: 03 Mar 2025, 17:56
12V feed?! 🤣
Broken wire or socket? Have you got a wiring diagram, is there a relay somewhere?
x 1968
Not got diagrams for the 93 td....my 97 S1 Activa ones show no relay/socket fuse @F16/20amp
Socket is fine, earth is fine (the light works thus the earth is good as it earths via the body to the sockets earth wire/black), no volts on Multi-Meter when I probed the connector on the back of the plug or when disconnected etc.
I have removed the fuse @F16 / swapped it a number of times.
The live (red wire) feed is totally dead, the fuse (I assume the correct one) @ F16 is live when the key is in the Acc position and when the car is running.
All other fuses etc work/show volts/all probed
x 1341
Unread post by xantia_v6 »
The wiring diagram indicates that F16 is the correct fuse. I suspect that you have a faulty fuse board, maybe a bent fuse contact, or maybe a bad soldered joint on the board.
Did you try inserting F16 in the other (permanent live) position?
x 1968
xantia_v6 wrote: 03 Mar 2025, 20:25
Which is ?
x 1431
Is it possibly one like the shunt on later cars where there are 2 positions, one is switched and one permanent live?
x 1968
Not sure........wil look this morning ....BUT
There are never any volts ..... even when the car is running/no matter what key position.
peter306
x 60
Unread post by peter306 »
up to 1998 diagram, from the haynes book
Citroen GSA flat4 engine written off
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen Xantia 1.8 gone
Citroen Xantia 1.8 still living now 148 k
peter306
x 60
Hi Alasdair,
PM me your postal address and i'll post the manual to you.
As mines a 2000 and I have the manual for that
Citroen BX 1.4 gone
Citroen BX 1.6 gone
x 1968
Hi Peter....is it for a 93 early type ??
.....if so that would be great !
peter306
x 60
Hello,
1993 to 1998
K to S reg
Citroen BX 1.4 gone
Citroen BX 1.6 gone
x 1431
Looks like a simple circuit. Pop the fuse out and check it's not blown. Check for 12v on the fuse box outlet connector (pin A7 of a 13 pin brown connector). Check for 12V at the socket connector. This will tell you if it's the fuse, fusebox, or wire and you can repair accordingly.
x 1968
At the moment I am looking at a break/failure in the feed wire.....access is rather problematic for my big hands so finding where will be a pain (literality !)....with luck it has flexed close to the tray which will allow a joint to be added.....if not I will run a fly wire from a piggy back fuse and do the job when the dash comes out in the summer.
