P Level Low Error
ne8ryan
x 4
P Level Low Error
Unread post by ne8ryan »
Hello,
just refuelled my car and got back to a "P Level Low" error with a service light on the dash,
I understand from a bit of research that the EOLYS Fluid needs to be replaced which it is booked in on Wednesday however,
how safe am I to drive it, would just be city driving, probably 60 miles? Won't be going 70mph for more than 10 minutes straight give or take.
Citroen DS3 1.6 HDI 2011
Thanks.
Tech nerd.
MPG > Performance
x 1487
Re: P Level Low Error
No problem at all - it only injects a very small amount when you fill up - there is no level sensor in the tank it's just an estimate, and comes on with quite a bit left.
x 1942
Unread post by Paul-R »
To be honest, that won't make any difference. Eolys is only added to the fuel after a fill-up. So, as long as you have enough fuel in the tank for a couple of days, then just drive normally.
ne8ryan
x 4
Paul-R wrote: 03 Mar 2025, 15:28 To be honest, that won't make any difference. Eolys is only added to the fuel after a fill-up. So, as long as you have enough fuel in the tank for a couple of days, then just drive normally.
I never knew that, I wonder how it knows when to add in new fuel, clever. Thanks!
RichardW wrote: 03 Mar 2025, 15:25 No problem at all - it only injects a very small amount when you fill up - there is no level sensor in the tank it's just an estimate, and comes on with quite a bit left.
Ahh that's excellent, it's booked in for Wednesday anyways so no more driving after today, got quoted £60 plus labour..
Thanks for all of the help.
Tech nerd.
MPG > Performance
x 1942
ne8ryan wrote: 03 Mar 2025, 17:03I never knew that, I wonder how it knows when to add in new fuel, clever. Thanks!
It used to be that every time you opened the fuel filler flap a magnet would activate a sensor which would then trigger the injection of the Eolys. The system didn't know how much fuel you had put in so would squirt in a high amount. Bad news if you only top up in dribs and drabs.
The system is cleverer now and I believe just checks to see if the fuel gauge has had a sudden increase after being switched off. If yes then the system has a much better idea of how much fuel has gone in and can add a more measured amount of Eolys.
ne8ryan
x 4
Paul-R wrote: 03 Mar 2025, 17:43
Ahh gotcha. Minimum amount I put in is £20 which normally equals to half a tank on the fuel guage, most I put in is £60 which is a full tank, how the maths add up, I'll never know but Costco fuel is decent quality.
Tech nerd.
MPG > Performance
x 6957
If the vehicle has a fuel flap sensor, this is only used to inform the engine ECU that fuel may have been added, and to start a fuel level calculation measurement. Some later systems don't bother with the fuel flap sensor now in any case and just do the fuel calculation measurement regardless.
It takes a reading when the engine is stopped and again when restarted - checks the difference and determines the amount of fuel and therefore the amount of Eolys to inject.
