I have a citroen c4 grand picasso (2015) which I took for MOT on monday, had lots of work done this year and no warning lights were showing when I dropped the car off,
However when I picked it up it had failed due to airbag warning light on dash (100% wasnt there when dropped the car off!!)
Took the car and had diagnostic run and it is showing fault code B0001 Resistance too high "Level 1 drivers air bag line fault" & U1F00 Not Characterized "Fault not recorded in the built in systems interface faults log"
Any ideas? Is there anything I can try?
B0001 fault code on Citroen C4 Picasso
- x 6950
Re: B0001 fault code on Citroen C4 Picasso
The UF100 fault means that the BSI has not detected the occurrence of a fault that was sent by the specific ECU that recorded the fault.
You're missing the last 2 parts of the fault code, which may be a limitation of your diagnostic tool, but assuming it is B0001 1B:
ESSENTIAL: (*) Risk of pyrotechnic deployment, do not perform any measuring on the pyrotechnic line.
| Fault Code: | B0010 1B |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
