2007 Citroen C5 II P1403 and P1404 Fault Code
sydo
x 9
Unread post by sydo »
Hello everyone, my Citroen C5 does not start or has difficulty starting when started in the mornings in extremely cold weather. When this problem occurs, the glow plug light comes on and goes out when I turn the ignition. The engine starts easily during the day, the glow plug light does not come on. I changed the glow plugs but the problem persists. When I connect it to the computer, it gives the following error codes.
P1403 -Additional heater circuit 1: short circuit to positive -circuit error
P1404 -Additional heater circuit 2: short circuit to positive or open circuit -circuit error
sydo
x 9
Re: 2007 Citroen C5 II P1403 and P1404 Fault Code
Does anyone have any information regarding this issue?
Huskyxantia
x 901
Unread post by Huskyxantia »
Check the wires leading to 1 & 2 glow plug for any break , check the relay aswell (water ingress)
:-D
Huskyxantia
x 901
You need HellRazor5543 on here he's had a c5 & knows a few things about these cars.
:-D
sydo
x 9
What is the source of the problem and what is the cause of these codes?
[/quote]
Huskyxantia
x 901
Short circuit to positive is usually a live thats touching another wire, or blown a fuse or both find that sources line then check it , could be part of the loom has exposed some wires and there touching car body somewhere, check fuses first.
:-D
sydo
x 9
Huskyxantia wrote: 18 Sep 2025, 08:43 Short circuit to positive is usually a live thats touching another wire, or blown a fuse or both find that sources line then check it , could be part of the loom has exposed some wires and there touching car body somewhere, check fuses first.
Additional heater circuit error, which part gives this error code?
sydo
x 9
I haven't been able to find the source of this error code for months. If anyone has experienced this problem before and knows how to fix it, please help.
Huskyxantia
x 901
:-D
