Music not playing (Citroen C3 II)
This unit is the RD4 or RD45 system, made by Continental.
Usually standard equipment unless another system is specified as an option. There are Single & Dual Tuner versions. RD45 features over the RD4: The RD45 has USB connectivity & integrated Bluetooth module supporting Phone & Audio Streaming.
call_me_ced
Unread post by call_me_ced »
I have a 2012 Citroen C3 (1.2 PureTech) that I bough back in September 2022 and everything was great until earlier this year.
All of a sudden, music can't be played (no radio, no AUX, no CD, no Bluetooth). However, I can perform calls using Bluetooth (so I'm assuming the speakers work perfectly). Audio functions menu disappeared from the settings. Volume up/down, next/prev track and mode don't work (neither stalk nor main unit), unless in a Bluetooth call (I can volume up/down there and also long press on the mode to call/hang up the call).
I changed F8 and F9 fuses and also the 10A fuse on the media/radio unit, although none of them was blown. I also tried resetting the car by disconnecting the battery for ~15-20 mins and reconnecting again. It reset the date & time, but nothing else.
Multimedia screen is MONOCHROME SCREEN C (see attached).
Any idea how to fix this?
x 6963
Re: Music not playing (Citroen C3 II)
Hi, it's very likely to be the RD4 Head Unit. The fact that you're getting bluetooth calls is because there is a separate Hands-free module installed which handles the bluetooth side of things that talks to the display screen.
