Alternator charging amperage?
citc4
Unread post by citc4 »
Hello, the car is a Citroen C4 2.0 Hatchback, petrol 2007.
The alternator has failed, and needs to be replaced.
The car is standard, and I was wondering which charging amperage, the generator should be.
My options are 80, 90, 125 amperage. But the higher the amperage are, the more costly it will be.
Best regards
citc4
x 1485
Re: Alternator charging amperage?
Post the VIN and we can check.
citc4
RichardW wrote: 23 Feb 2025, 18:04 Post the VIN and we can check.
Hello, thanks for your reply.
The VIN number is VF7**************[VIN obfuscated, can be read by forum staff]
x 1485
There's a mistake in the VIN, I've corrected it above.
It's fitted with a 120 amp unit.
citc4
RichardW wrote: 23 Feb 2025, 19:03 There's a mistake in the VIN, I've corrected it above.
Thank you for your help!
Helped a lot-
Best regards
citc4
