I have 2013 citroen ds5 hybrid deisel message stop engine fault only code p1349.
Car in limp mode does anybody know what this is please.
Fault code p1349
OnlinePaulC5
- x 717
Re: Fault code p1349
A search suggests different things for P1349 so you will need to post your vin to see what it might mean for your car.
Leejasp
- x 6950
This fault relates to a pre-post heater relay fault - which should not normally result in engine backup mode, as the relay for the glow plugs is usually only used for cold starts or when commanded by the engine ECU for post heating during assisted regeneration. However as this is a hybrid version of the DS5, it may be something else - if you didn't use Diagbox, it's likely your code reader isn't advanced enough to read all the advanced constructor codes - especially for Hybrid systems.
| Fault Code: | P1349 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
