Citroen c4 grand Picassos blower motor location
krio1987
x 4
Unread post by krio1987 »
Hi there,
I have an issue with my blower motor on my citroen c4 grand picasso 2016 (diesel). You can hear ticking at slow speeds where it sounds like something is trapped or one of the fins has broken, and at higher speeds to makes a noise like a jet engine. I suspect that I need to replace it, however I don't know exactly where it is located to check and replace.
Does anybody know where it is and the procedure for access, saving me ripping out the whole dash. If I can go straight to it that'll save me a lot of time and effort
Thanks in advance :)
x 6955
Re: Citroen c4 grand Picassos blower motor location
krio1987
x 4
Thank you so much Marc, thats really helpful. I'll definitely make use of this :)
krio1987
x 4
Just want to say thanks for the help on this. I was able to locate and remove an erroneous leaf from the fan, which was the cause of the noise. Its all back to normal now :) Thanks Again Marc
x 6955
You're welcome.
