Xantia 1.8 16V Idle speed adjustment
shedload
Unread post by shedload »
Hi
I have a 1996 Xantia Dimension which stalls regularly. Can the idle speed be adjusted. I have been told it needs to be done electronicaly by citroen. Is this true or can I do it myself?
Eamonn
AndersDK
Unread post by AndersDK »
There is no adjustment on the idle speed [:)][;)]
Whoever told you so, must still be day-dreaming on the old days of carburettor fitted engines [8D]
You have a problem somewhere on the electronics controlling the engine.
Could be the stepper motor that's seized, or the map sensor, - or the trouble potientiometer.
And NO - it's NOT a question of "downloading" a new value to the ECU [:p]
Stuart McB
Unread post by Stuart McB »
O! OH! seems that this engine either over eving or stalling prolem is getting a little out of hand. Have recently replaced my Xsara's idel control valve, The old one was full of soot and c&&p. Your problem sounds like the MAP sensor may be full of old oil vapour. Not sure where it is ona Xantia but if you can remove it give it a clean out with brake cleaner NOT carb cleaner (to harsh) then let it dry on a warm spot like the aring cupboard with some paper towel underneth its fittings so any oil can drain out.
shedload
Once again the internet comes up trumps!
Cleaned the map sensor and all is fine
