e-C4 2022 P0C46 error code
JT99
x 3
Unread post by JT99 »
2022 e-C4 MK2 (UK spec.)
I read the DTCs yesterday with Car Scanner, and I have
P0C46(25) [0x0C4625]
Hybrid battery pack coolant temperature sensor - circuit intermittent/erratic
Status: Test failed, Confirmed
This has come back since I last cleared them- (there were 77 last time after the 12V had gone flat! now I only have 39, including this one and P2299 for pressing both pedals at once)
Is P0C46 a phantom code (it doesn't have a hybrid battery pack!), or is it something I need to raise before the warranty expires?
I'm not overly bothered by the other 37 codes, they are mostly marked as inactive, (which I assume means historic and not a problem now) the car seems to work, and having watched a couple of documentaries about the RAF, it seems typhoons have much worse electrical problems and they cost £150 million each. (Also the solution is still remove the power and turn it back on......)
x 6950
Re: e-C4 2022 P0C46 error code
I would stop intervening yourself if you have warranty and get it to the dealer! You risk rejection of warranty if you attempt any repairs or change anything, so be aware.
Sloppysod
x 407
Unread post by Sloppysod »
JT99 wrote: 19 Feb 2025, 09:25 2022 e-C4 MK2 (UK spec.)....... and having watched a couple of documentaries about the RAF, it seems typhoons have much worse electrical problems and they cost £150 million each. (Also the solution is still remove the power and turn it back on......)
I do like an optomist 👌👍
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
