2 worries I have at the moment concerning the rear heated screen and the heater blower.
I thought the heated rear screen switch was faulty as the light within the switch remained illuminated with the ignition turned on or off (I discovered this when I found the battery was flat) . I have replaced the switch but the same thing happens, so at the moment I have disconnected the switch and the connections on the back screen. I am presuming the relay has given up the ghost but I don't know where to find it, what colour it may be etc.
My next problem is that the heater blower has stopped working. I have been told that the blower should work even if the blower motor resistor is at fault but it doesn't so I am presuming the motor might be the culprit, however, before I remove it are there any in situ tests I can do to determine if it needs replacing. When I checked the resistor I did rotate the blower fan from the vent cover under the vent panel, it was not seized and rotated quite freely.
I know there is a vast wealth of knowledge on this forum so I am hopeful there may be someone who can advise me.
Cheers
ZX 1.9D Estate electrical worries
- x 1060
Re: ZX 1.9D Estate electrical worries
Assuming all fuses are OK the common link will likely be the age old problem on older Citroens of the ignition switch failure.
