Berlingo NOx Issue
Willibuyaberlingo
Berlingo NOx Issue
Unread post by Willibuyaberlingo »
Did you ever find a solution?
I have the same three errors on my 2017 Berlingo.
The fault codes are:
U029D 87 - communication fault with the deNOx system
P2200 87 - NOx sensor component detected not communicating on the emission control network
P3057 00- particle filter estimated number of particles incorrect.
Thank you
Reason: Moved to a Separate Thread
