SMEG Jukebox
This section is for General Enquiries or for Systems not Covered Above
x 1942
SMEG Jukebox
Unread post by Paul-R »
GiveMeABreak wrote: 06 Feb 2025, 11:41There's no physical jukebox Matt, it's a feature of some Head Units ... It's not available on the SMEG units as they don't use HDD,s only flash memory and space is likely limited.
The SMEG+ unit on our Peugeot 308 most definitely does have a jukebox. It's not something I ever used and I changed the partitioning on the SD card so that so that some of the space previously allocated there became available for the extra large map data in later map updates.
Reason: Moved out of Parts Thread
x 6946
Re: SMEG Jukebox
I meant it does not allow transfer of CD files to the Jukebox. Probably only MP3s from other sources like the USB:
Role
The CD player plays audio Compact Discs (MP3 format supported).
N.B.: The CD player does not permit the transfer of audio files to the Jukebox.
I suspect it's because of the space that CD Rips take up, as opposed to MP3 files that are much smaller in size.
x 2938
Re: SMEG Jukebox
x 1942
Re: SMEG Jukebox
GiveMeABreak wrote: 06 Feb 2025, 12:55I meant it does not allow transfer of CD files to the Jukebox.
As you've removed my post from that thread you should go back, if you haven't already done so, and clarify your original post.
