I was wondering if someone could help me out. I can only find one and need to know if that is the only one.
And if someone can suggest the best way to get air out as I’ve recently had someone do me a coolant drain, flush and refill but hearing a sloshing sound when I start my engine up.
I’m not a car expert at all and hope someone would be kind enough to help me out.
Coolant Bleeder Valves - Citroen C4 Picasso Exclusive 2014 Semi Automatic
NathanJohnson98
- x 1498
Re: Coolant Bleeder Valves - Citroen C4 Picasso Exclusive 2014 Semi Automatic
What engine is in it?
NathanJohnson98
How do I know which engine it is? Pretty sure it is the standard one that comes with a C4 Picasso. Not been told anything from when I bought the car and I recently had Citroen carry out repairs and they didn’t mention anything either.
- x 1498
Er... well there are 1.6 and 2.0 diesels, and some petrol versions, not sure which at this age. It's most likely a 1.6 diesel - what's the VIN?
NathanJohnson98
It’s a 1.6 that’s for sure if that helps and I can get the VIN later after work and it’s diesel.
