Best ODB11 for C5 X7
Dadsaster
Unread post by Dadsaster »
Hey forum.
New here. What would you recommend as diagnostic tool/ fault reader for Citroen C5 X7 2009?
Used to VCDS interface for VAG. Anything similar?
Or sollution for Android via Bluetooth?
Best regards
Kees
x 150
Re: Best ODB11 for C5 X7
Unread post by Kees »
AliExpress!!!
cit-rotti
x 78
Unread post by cit-rotti »
Dadsaster wrote: 01 Feb 2025, 20:26 Hey forum.
Best regards
viewtopic.php?p=827816#p827816
Mihael_M
x 37
Unread post by Mihael_M »
If you are only looking for reading and erasing errors, an OBD2 scanner can help. For example, this one:
https://www.aliexpress.com/item/1005006 ... 1802nINugO
There are cheaper ones, but this one can work better.
With it you can use: Torque, Scanmaster and similar programs on your Android phone.
With Vgate iCar Pro you can use https://faplite.en.aptoide.com/app which is great for engines with FAP.
For more serious things you should have Diagbox with Lexia 3.
