Rear bushings
mvts
Rear bushings
Unread post by mvts »
I have a C5 2.2, Crosstourer 2014.
I have a question about the bushings in the rear suspension.
Both rear tires wear out quickly and I find the car sways at the rear, especially when you drive over a bump in the road.
I understand that there are many bushings in the rear suspension. But is there one in particular that usually has bad symptoms with my symptoms?
Thanks!
fuel__2001
Re: Rear bushings
Unread post by fuel__2001 »
Hi
Be useful to confirm it's the bushings. Its fairly straightforward to change them but is quite involved if your going to tackle it a home.
This clip is for a C4 but you'll get the idea
mvts
Re: Rear bushings
fuel__2001 wrote: 07 Feb 2025, 18:31 Hi
Thanks!
