which diagbox do I need to buy for a win 7 laptop with 64bit
my older 32bit lappy had version 7.02 on it and installed and worked fine [laptop now dead], but the same software doesnt want to run with 64bit
ta
diagbox for win7 64bit
nikeastwood
- x 24
no egr, no dpf, no problems.
- x 6947
Re: diagbox for win7 64bit
It won't. Diagbox version 7.** is not designed for 64 bit operating systems. Although the 32 bit 'Diagbox' programme will run on a 64 bit OS, the sub-programmes contained within like Lexia and Peugeot Planet 2000 will not run natively under a 64 bit OS as they were written in 16 bit code.
You may only resolve this using a virtual machine which your laptop must have the capability to run and the memory resources to go with it.
cit-rotti
- x 78
If you do not have a laptop that is suitable for a VM installation, you can install a native installation of software version 9.xxx suitable for WIN7 64 bit pro as an alternative to the 7.xx VM software version, e.g. the native software version 9.216 - activation code 15 €.
There are also free native 9.xxx software versions. Please note, however, that most 9.xxx software versions require WIN 10 or WIN11 64 bit and that no virus software may interfere with a native installation - not even Windows Defender.
Most VCIs that worked with the 7.xx software also work with the 9.xxx software - but sometimes they don't - you have to try it out.
Good information on this can be found at
https://guiapsa.foroactivo.com/login
Wolfgang
Wolfgang
Mihael_M
- x 37
https://guiapsa.foroactivo.com/t2128-05 ... s-18-12-24
Why would you use a VM if you have Win 7? I use 9.85 and 9.150. Those versions are free as well as this Robert version.
cit-rotti
- x 78
The versions 9.85 and 9.150 are from Robert at https://guiapsa..es there is also the 9.199.
If you want to use these correctly, the firmware must be adapted according to Robert's recommendation. Both versions are good but not perfect. This is what ‘Robert’ always writes; whereby the 9.150 etc. is based on the 9.85 and manual corrections have been made, i.e. it is not a true copy of the original software. For the usual diagnosis probably without restriction/meaning.
See also my recommendation:
There are also free native 9.xxx software versions and that no virus software may interfere with a native installation - not even Windows Defender.
If possible, the laptop should then only be used for diagnostics.
Even if VM versions are somewhat more complicated/expensive to use, this has the advantage - provided that the laptop is technically suitable - that the laptop can be used for other activities and there are no virus problems.
If a 7.xx software version is preferred for good reasons and not only the Diagbox but also the LEXIA 3 or PLANET is required for older vehicles, then only a VM version is possible with a WIN 64-bit system. If the software part for the older vehicles is not required, then the Diagbox 7.xx can of course be installed on WIN7 or WIN10 64-bit, because the DB is a 32-bit system.
Wolfgang
Wolfgang
Djandree
- x 38
Look for psa-diag fr
nikeastwood
- x 24
I threw another £3.50 at aliexpress, that got me a download of Diagbox 9.85 which works directly on Windows 7 [and above] no VM Player needed, and no faffing around on the install, it works on my 64bit just fine.
https://www.aliexpress.com/item/1005008270021538.html
- x 6947
But be aware the older encapsulated versions of Lexia and PP2000 contained within Diagbox will not natively work on those older vehicles as they were written in 16 bit code which is not supported under native 64 bit Operating Systems.
cit-rotti
- x 78
As of Diagbox Software 9.25, PSA has converted everything to 32-bit, so that the old software for Citroen (LEXIA 3) and Peugeot (PLANET 2000) can of course also be installed on any 64-bit system.GiveMeABreak wrote: 22 Mar 2025, 13:38 But be aware the older encapsulated versions of Lexia and PP2000 contained within Diagbox will not natively work on those older vehicles as they were written in 16 bit code which is not supported under native 64 bit Operating Systems.
- x 6947
Great thanks for the update on that
cit-rotti
- x 78
You do not have to pay anything to download diagnostic software, e.g.nikeastwood wrote: 22 Mar 2025, 13:33 I threw another £3.50 at aliexpress, that got me a download of Diagbox 9.85 which works directly on Windows 7 [and above] no VM Player needed, and no faffing around on the install, it works on my 64bit just fine.
