308cc small seal leak
Huskyxantia
x 915
Unread post by Huskyxantia »
Shout out to anyone with a 308cc , the joint at the driver window has developed a slow drip , whats the best way to fix or cure this ...... 🤔
:-D
x 1460
Re: 308cc small seal leak
Unread post by xantia_v6 »
Which joint? Ours doesn't have any leaks (with the roof up and windows closed :wink: ).
Huskyxantia
x 915
The joint in the red circle, it will have a drip , windows up roof on , when it rains real hard. The rubbers sort of go inside of each other . I've just put some grease over the joint as a temp fix , the drip has slowed down but still leaks.
:-D
