Just joined this group hoping to find the cause of an abs problem on my daughters car.
Car is a DS3 1.6 hi 90bhp. MY2014.
ABS light and traction control light recently came on. Plugged it in and was showing error code. C1331 front right wheel sensor signal fault. I changed the sensor and cleared the error code. Soon as I took it down the road the lights are back on with the same error code. Anything else common with this issue please?
DS3 abs problem.
- x 6945
Re: DS3 abs problem.
It may not be the sensor itself, see below. There may be some corrosion in the front pivot which incorporates the magnetic poles for the front wheel speed sensor to read, or look at the wiring connections.
| Fault Code: | C1331 |
| Description of Fault: |
| Conditions for Fault to clear: | Front door exterior opening control handle; Vehicle speed higher than 20 km/h |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
Bluies63
I'll look into it weekend. Thank you.
