Hi all,
I have diagbox 9.180 running native on windows 10. I have been fault finding some issues with our 2014 C4 Picasso B78. VIN: VF7**************[VIN obfuscated, can be read by forum staff]
The faults I have fixed were broken abs wiring rear drivers side and passenger side door mirror broken wiring which prevented the blind-spot system from working.
These faults seem to be remedied now but I wanted to do a purge of other faults thrown up in the report, particularly any that may be significant and drive for a week and run another global test and see what comes back. I have mostly done this but had an extra warning message when it came to clearing the 11 faults listed under the Engine Management ECU. It said something about maintenance steps needing to be performed I think so I didn't proceed any further. How do I proceed with that please?
The Engine Mngt ECU faults that concern me are below if anyone could offer some further insight or experience. At this stage, (short test drive after repair) the only thing that doesn't seem to be working is stop / start (yet again and it hasn't for a while). The battery was a new AGM compatible unit about 18 months ago. The new battery was prompted by the fact I knew it hadn't been changed in the 5 years of owning the car and Stop/ Start wasn't working. The new battery did get S/S working again at the time. That's all that I notice is wrong.
P1AA5: Voltage maintaining device - Internal fault - partial destruction of switch.
P1382: Ancillary Drive Belt(s) Fault in coherence between the engine speed and
the alternator speed.
P1694 Controlled Engine Start and Stop - Fault on the starter motor control line
P0571 Inter-systems CAN - Lack of coherence of the brake pedal position
sent by the BSI
Thanks in advance.
Clearing Engine Mngm't Codes with Diagbox query
Byngo9
- x 7
wurlycorner
- x 271
Re: Clearing Engine Mngm't Codes with Diagbox query
Hi there
Have any of those remaining faults actually been investigated to diagnose if they are genuine etc and any repair carried out to correct them?
Iain
CX DTR T2 Safari (silver)
Iain
- x 6957
You should be aware that the stop start system on your vehicle is not only to do with the main AGM battery. It is fitted with a specific Stop Start system that you won't be able to see as it's hidden under the front left wing and contains a network voltage maintaining device and ultra-capacitor that are the main components of the system.
The P1AA5 fault relates to this:
| Fault Code: | P1AA5 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P1382 |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P1694 |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0571 |
| Symptoms: |
| Suspect Areas: |
Byngo9
- x 7
Thanks for the breakdown Marc. Car not throwing any service light ( since I fixed the ABS wiring anyway).
No slipping of the aux belt that I'm aware of but I'll have to investigate the belt condition and tensioners I guess. ( I was planning to renew cam belt and aux belt this summer anyway).
Stop start I'm not so fussed about persee, but something potentially related back to a root cause of aux belt raised my level of concern.
So what about that Diagbox warning of needing to perform / confirm some maintenance operations first, when trying to clear the faults. I can't remember exactly what it said but how do I proceed through the menus to clear the faults. ( I want to see what comes back initially).??
- x 6957
Without knowing the exact message / fault / context, I can't advise regarding the 'maintenance' message you are receiving.
Byngo9
- x 7
Ok, I'll take another look at the w'end and screen shot it. The message about maintenance operations only appears when going through the motions of clearing any engine management ECU faults. I have not seen it when clearing other ECU faults.
OnlineRichardW
- x 1487
It probably said you need to create a maintenance event, this is just a record of when the codes are cleared. It only allows 10 or something, after that it just says you can't do it, but let's you proceed anyway.
- x 6957
Yes, if it's the memory slots for diagnostics, just ignore it. It allows something like 50 memory slots for recording fault clearing - and then warns that you won't be able to save any more.
Byngo9
- x 7
Yes, that makes sense as I remember seeing something about 4 of 10 slots used.
