Citroen Dispatch 1.6hdi HELP
Bhuna
New User
Unread post by Bhuna »
I've got a 2015 Dispatch 1.6hdi starts fine and will rev to 5000+rpm then as soon as you stick it in gear it goes into limp mode. Won't rev above 2500rpm sat idle or 3000rpm driving. 2nd gear up hills it's just gutless
The only DTC codes up are;
P0460 Fuel Level Measurement - Variation Outside Tolerance
0157 External Air Temperature Information Not Valid - No Signal
I've replaced the fuel sender unit and the temperature sensor resistor in the drivers mirror. The fuel gauge works and is accurate and the temp display shows 2 lines no temperature
Has anyone got a wiring schematics diagram for the fuel sender unit and temperature sensor or have any suggestions on what to check????
Noticed tonight the hazzards don't work and the screenwash hasn't worked for a while. Any help of suggestions greatly appreciated....
moizeau
x 423
Re: Citroen Dispatch 1.6hdi HELP
Unread post by moizeau »
You'll need to be more specific on what engine/age or post your VIN, no spaces, only the chosen few can read it and it will be masked to us mere mortals
Pete
PaulC5
x 696
Unread post by PaulC5 »
Screen wash could be a blown fuse if you have tried to use it when frozen. We had a C3 that did this a lot.
