Hello!
I am trying to repair a Citroen Xsara Picasso 2006, 2.0HDi. This car has a problem while driving, as the engine power falls (decreases)... I have to change speeds 5-4-3-2-1 then again 1-2-3-4-5.
Someone used a diagnostic tool on my car, so I get this error (no other errors appears):
P1521 - Clutch switch signal; consistency with vehicle speed
Could that switch cause this problem?
Personally I though this is the MAF sensor causing the problem, but now it is unclear to me if the clutch switch could cause the power to fall.
Thank you for your help!
Xsara Picasso 2006 2.0 HDi - engine power decreases while driving
ITChristian
