Airbag light stuck on. Gives pretensioner fault.
ollie2110
I purchased a 207 GTI, where someone has tried to fit 208 seatbelt pretensioners and steering wheel into the 207. I swapped out the 208 seatlbelt pretensioners for 207 ones to make sure this wasn't the issue. I then swapped back in the 207 steering wheel and airbag. The fault code is listed drivers side/passenger side pretentioner serious fault - open circuit. I've plugged new 207 pre-tensioners in with no luck. Is there anything else I can try?
